What I learned from doing this conversion.
I just completed mine yesterday. Make sure that you have the banjo bolts, that hold brakehose on, from the donor car. You will need to use the brakehose from the 93, new crush washers, and the SN95 banjo bolts. The banjo bolts from the 93 will not work on the newer calipers. Not sure about the brake master cylinder, my car started as a 4 cylinder car so I just replaced it to be safe.
If your car started out as a 4 cylinder car you will need to get GT front brake hoses, as well as new struts, and master cylinder.
