Got my Wheels set - now tires.
I went with TT2 (of course) 17x8 in front and 17x9 in rear. I like the agresive stance, what size tires should I go with?
I've been reading 235/45 front and 275/45 rear? Is that correct? Any better combinations out there?
My bad guys... she's a 68.. :D
But I just noticed as i was checking out. I can get the 17x8 for the 68 stang, but the 17x9 said it was as follows:
+24mm offset (5.95" backspacing) - fits Mustang 1994-2004 with 5x4.50" (5x114.3mm) lug-pattern.
Can I use the 17x9 or better to just get x8 all around?
From my research now im swaying towards 235/40 front and 275/40 rear? :shrug:
I too dont believe in the same size tire. This is just a cruiser - I've decieded to keep it easy and go with 17x8 on all 4 corners...
Now should I go with 255/45 (or is it 40 not sure) on rear and 235/40 on front?
I want an agresive stance - will be doing the grab-a-trak suspension.
I don't have mine mounted yet, so I cannot tell you how it worked out, but..
I went with 275/40/17 for the rear and 235/45/17 on the front.
-8x17 for the front w/ 4.75 bs and 9.5x17 with 5.5 bs for rear.
Here is a good site to compare the sizes.
http://www.1010tires.com/tiresizecalculator.asp?action=submit
What backspacing did you go with on the front and rear?
Just checked out the 1010 site. I was comaparing the dimensions of the tires, and it stated that I would need a 8.5 - 9" rim to run a 255... Is that correct? I thought I heard of plenty guys here running 255 on a 8" rim...
Also anyone running a 255/45/17? I think I'd like the extra width in the sidewalls for the rear to look a little bulkier. I wonder if it would fit.
