  • SN95 4.6L Mustang Tech
Got subframes welded on today, stupid ?
  • Thread starter Thread starter TweekedGT
  • Start date Start date May 3, 2005
1 of 2 Next Last
TweekedGT
1,274
Alberta
May 3, 2005
  • May 3, 2005
I got my Maximum Motorsports subframe connectors welded in today. I know this is a stupid question since I already bought the things and had them installed but what is it that they do exactly? Everyone says it is one of the most important mods. I haven't really noticed a difference now that they are in. I am primarily a drag racer. How will these help me? I know the gist that they connect your subframes and are supposed to help cut down on frame twist and body roll but I'm not sure how this will cut any time off my 1/4 mile.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
May 3, 2005
  • May 3, 2005
They will help your traction alot,reduce
body roll,reduce nose dives,and help
stop side to side sloppyness.SFC's are
a very important mod and will stiffen
the chassis.
propellerhead
1,541
"but what's with the but shots?"
May 3, 2005
  • May 3, 2005
The twisting frame absorbs energy that could be better spent moving your forward. It's the same principle behind swapping in solid motor mounts and stiffer bushings everywhere.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 3, 2005
  • May 3, 2005
They stiffen the chassis. Combine it with a strut tower brace for ultimate stiffness. Do not get a two point strut tower brace. Do not get a strut tower brace that screws up your alignment every time you remove it...
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
May 3, 2005
  • May 3, 2005
I've got a vert...I'm thinking I need some full length subframe connectors too
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 3, 2005
  • May 3, 2005
I think a lot of verts come with them stock. At least mine did... Are you sure there are none under there? Verts need them especially because they do not have the roof to tie the unibody together...
GDawg
1,469
Nevada
May 3, 2005
  • May 3, 2005
Yes, you should.
And no, '98s didn't come with any.
twogts4us
4,188
12
79
Dunedin, FL
May 3, 2005
  • May 3, 2005
the chassis.
Not sure what you mean by side to side sloppiness, reducing body roll or reduced nose diving being corrected by SFCs - that sounds more like what better springs/shocks/struts/swaybars will do for you.
Propellerhead has the right answer here - that twisting motion absorbs alot of energy.
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
May 3, 2005
  • May 3, 2005
i hate to but in this conversation but why would a strut tower brace off a 94 gt not fit my 98 gt?
mustang70
2,445
San Diego
May 3, 2005
#10
  • May 3, 2005
  • #10
The intakes are completely different. The 94 is a 5.0 and the 98 is a 4.6.
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
May 3, 2005
#11
  • May 3, 2005
  • #11
i know.
twogts4us
4,188
12
79
Dunedin, FL
May 3, 2005
#12
  • May 3, 2005
  • #12
jamez1502 said:
i know.
Well, if mustang70's post didn't clue you in enough, I'll sum it up for you - No, it won't fit.
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
May 3, 2005
#13
  • May 3, 2005
  • #13
twogts4us thanks for that..
mustang70 i didnt mean to sounds like a smart ass the intake isnt getting in the way the plastic on the firewall is what is blocking me..
CanadaStang
2,093
Mb
May 3, 2005
#14
  • May 3, 2005
  • #14
Mustangs use a uni-body design where the separate sub-frames are which your major suspension parts are attached to.They work exactly as they sound, tying the front and rear sub frames together to make a stronger platform. The stiffer the chassis is, the more effectively the rear suspension can do its job and put the power to the ground. This in turn will help your car to achieve a better weight transfer upon acceleration thereby giving you better launch times off the starting line and helping to lower your overall E.T.’s. And as propeller head says, you won't have as much wasted energy with a stiffer chassis.
NasaGT
1,993
Virginia
May 4, 2005
#15
  • May 4, 2005
  • #15
Verts have shorty subframes that are BOLTED in. Full-length subframes that are welded in make a huge improvement in chassis stiffness. Every vert owner should upgrade to full lengths.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 4, 2005
#16
  • May 4, 2005
  • #16
No that is not correct.
DELOS02GT
461
Naperville, IL
May 4, 2005
#17
  • May 4, 2005
  • #17
I have the bolt on POS's from the factory on my car. I had Kenny Brown subs on my GT and was very happy with them. I didn't put subs on my '91 and had a very large crack on the underside of the car. IMO getting subs put on not only helps you put the power to the ground, but they add much needed strength to the chasis. In other words...you made the right move in getting them!!
StangPro
441
Roseville, MI
May 4, 2005
#18
  • May 4, 2005
  • #18
It kind of is.
Some verts, all Bullitts, some Cobras, and all Mach 1's have the flimsy tin foil stock bolted in garbage.
Red35th
609
Houston, TX
May 4, 2005
#19
  • May 4, 2005
  • #19
It more than likely wont even be a close fit. Ford relocated the strut towers for the modular cars. I test fitted my cousin's from his 94 Cobra and it was about 3 inches off (think it was too long, don't remember).
Sub-frames will also help keep your mustang from turning into a rattle trap. The constant twisting of the body in part creates all those squeaks and rattles. I could tell a huge difference, especially pulling out of driveways after mine were installed.
Chili
174
Euless, TX
May 4, 2005
#20
  • May 4, 2005
  • #20
It will help the shop too when you have to replace your axles..
1 of 2 Next Last
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
A
EEC-IV SFI-MA12A
  • amps1956
  • May 6, 2025
  • Other Auto Tech
Other Auto Tech Jun 25, 2025
General karthief
