Got the motor and flywheel in now new prob
ok guys heres the deal... i got my motor trany and flyw heel in .. but now ic ant get my 67 stang to start.. here is what i have if you havent been following hte flywheel problems post i was having. i havce a 67 mustang coupe with an 88 gt HO motor and a 1967 c4 from a falcon. ok heres the deal i have spark in my plugs i have spark at the coli and ignition. but the car still will not start. ive recheck and recheck all wires. all are hooked up right. and i have spark. but no start. any one have any suggestion on why it wont start.. it maybe outa time but i didnt have my timing light today so i didnt get to check that. but i do have it in the right fireing order.. or atleast by the book i do. well any help would be nice.. but i have to wait til monday to get back int eh shop to play some more. so any
Fuel problems?
Does it turn over?
Does it try to fire?
Do you get spark through the plug? Hold the plug against the block with something non-conductive and crank it, see if you get spark.
Do you have an electric fuel pump?
Fuel lines hooked up?
start from scratch.
pull #1 plug, stick your finger in the hole, and have someone tap the key til it blows your finger out.
then slowly turn the engine by hand until the timing mark is on "0" TDC
pull the cap and see where your rotor is facing.
yep... what worth says.
Do that and make sure its pointing toward the #1 wire. Turn it counter clockwise just a bit to advance the timing. Tighten it down try starting it up. You are using the new 302 firing order correct??
yeah thast what we thought to that it was outa time. so i pulled the cap and did the whole top dead center thing.. but it was getting late so i just tried it once and decided to call it a a night.. i am going to look at it monday at the shop when im at work. just wanted to see if any other thing besides the timeing would cause that
