Hey all,
I changed the valve cover gasket on my ol' 2.3 today. After making sure all of the hoses, linkages, nuts, and bolts were all securely tightened, I continued to try to start my car. I was able to get it to start, but I noticed that it was running a little rough. I let it run for a little while, and decided to take it out for a drive (to charge up the battery). When I put it in reverse it started to sputter and finally died. When I try to restart it, it acts like it wants to start but it can't. It turns over, and I can hear the fuel pump come on, but it won't start. I kept trying to start it, but wore the battery down again. Has this ever happened to anyone else who has removed the intake/throttle body assembly? Does any body have any suggestions? Thanks!
Its more than likely a vaccum leak or you forgot to plug something back up. Think about it, did you mess with anything that would involve fuel????? No, you prob didnt with just doing a valve cover gasket. Double check all your elec plugs (t.p.s. , i.a.c, e.g.r ) on the throttle body. Make sure all of your vaccum hoses are hooked up( shouldnt have to worry about them if you just removed the throttle body). A car will run on stale fuel just not very good. We pulled an 88 coupe out of the field where it had been sitting for two years and if fired up no prob with the gas that was in it.
