Granada Disc Conversion
  • Thread starter Thread starter jazzyjeff
  • Start date Start date Oct 15, 2006
J
jazzyjeff
  • Oct 15, 2006
So I Finally found a set of granada spindles,discs,etc to swap into my 65 V8. I hear there are issues with the tie rod ends,I need a bushing? What brake hoses work on this?How does this swap effect front end geometry? I hear rumurs it changes things? Can I keep my sway bar? Should I do it differant and use one of the kits that uses the original spindles? Any insight will be appreciated.
Jeff B.
2bav8
2,511
Mesa, AZ
Oct 15, 2006
  • Oct 15, 2006
Wow, lots of questions and most are answered by using the search feature.
Tie rods are often too long to set toe settings. Nothing a dremel can't fix, or even better a set of Baer Tracker outer tie rods. They also help "fix" some of the suspension geometery caused by the Granada spindles.
Granada calipers will use Granada brake lines, however, I recommend upgrading to some Russell flexible stainless steel brake lines as they only cost a few extra dollars.
Spindles have no effect on your sway bar. Keep it unless its the factory sway bar and in which case I recommend a 1" sway bar.
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Strut rattle
  • JD1964
  • Apr 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 22, 2025
manicmechanic007
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
