Granada Spindle Geometry
  • Thread starter Thread starter danny clemens
  • Start date Start date Dec 11, 2005
D
danny clemens
728
  • Dec 11, 2005
I was just on another site that stated that the Granada spindles would sit the tire and wheel back about an inch farther than the original spindles. Is that correct? I was going to do this swap with my 66 but I don't want to shorten my wheelbase. Thanks for answers in advance.
2bav8
2,511
Mesa, AZ
Dec 11, 2005
  • Dec 11, 2005
What you read was incorrect.
The Granada spindles do NOT change the wheel spacing. Or, in other words the backspacing on your rims will not need to be altered. However, as an example Wilwood brakes DO have a 1" wider positioning and would require new rims with additional backspacing to properly fit.
HistoricMustang
2,359
Confederate States of America
Dec 11, 2005
  • Dec 11, 2005
Danny may be thinking about the wheelbase changing on the car (less than 108"). In that case the information is also incorrect.
HistoricMustang
www.historicmustang.com
rbohm
6,698
550
204
tucson,az
Dec 11, 2005
  • Dec 11, 2005
yep, the only geometry change with the granada spindles in the bump steer. the steering arms are different between the early and late cars.
D
danny clemens
728
  • Dec 12, 2005
Thanks guys. That was what I was wanting to hear. I can now go forward with my swap.
bsedwebt70-5.0
320
Charlottesville, VA
Dec 12, 2005
  • Dec 12, 2005
Granada spindles in my 70 mustang - work PERFECT - just use the right ball joints and tie rod ends as the chamfer is different - the spindle is thicker too (stronger than the 69 and earlier units - much like the Boss version) Cheap to get new rotors, pads, bearings, calipers, etc... from the local parts store too.... I did the 1.5 inch drop on the upper control arm at the same time and put a homemade wedge between the upper ball joint and the upper control arm to set it in the middle again - car handles like it is on rails - highly recommend - also heavy front and rear sway bars installed....
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Sloppy steering wheel
  • cnorman31
  • Nov 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
Monkeybutt2000
M
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
