granada swap info needed
  • Thread starter Thread starter mikec35
  • Start date Start date Feb 18, 2008
mikec35
233
NC
Feb 18, 2008
  • Feb 18, 2008
I took the front disk brake assembly off of a 76 (I think) granada at a junk yard about 10 years ago and they have been sitting in my garage ever since. I am getting ready to clean them up and install on my 67 fb. I do not remember if they came off a power brake car or not. Does it make a difference if they were power or not? Is the booster the only difference between power and manual? Thx
D
D.Hearne
11,730
south louisiana
Feb 18, 2008
  • Feb 18, 2008
Manual disc master cylinder is different. You do not have to use a power booster. I didn't way back when I did a drum to disc swap on a 67 fb. Went from 4 drums to 4 discs with 71-73 Stang fronts and a Versailles rear. I used a 71 Ford Custom manual master cylinder w/o power assist. This one had a 1-1/8 bore.
mikec35
233
NC
Feb 18, 2008
  • Feb 18, 2008
Will the 67 manual master dual reservoir cylinder work?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Feb 19, 2008
  • Feb 19, 2008
I'm going to guess that since you are puting Granada brakes on your car that you have drums on your car now and not the 4 piston K/H calipers. If this is the case then you should not use the MC you have in there right now. The residual pressure valve built into the MC will cause the brakes to drag all the time.
D
D.Hearne
11,730
south louisiana
Feb 19, 2008
  • Feb 19, 2008
And the piston bore isn't big enough for the disc's caliper pistons.
mikec35
233
NC
Feb 19, 2008
  • Feb 19, 2008
I guess I could go to the auto parts store and get a master cylinder from the same year granada. Will it bolt up without any modification? I know I will probably have to bend the lines. While I am at it and my engine is out of the car how difficult/expensive is it to convert to power brakes? Any suggestions for a reasonably priced booster/cylinder set up? thx
D
D.Hearne
11,730
south louisiana
Feb 19, 2008
  • Feb 19, 2008
If you've got a big block in there, you're better off without a power booster.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Feb 19, 2008
  • Feb 19, 2008
There are so many power brake conversion threads out there. Use the search button. If we get into that on this thread it will get way off track... trust me.
ultrastang
1,092
Arkansas
Feb 20, 2008
  • Feb 20, 2008
I did the same swap on my '68 back in 1990 with wrecking yard parts. After the cost of the Granada junkers and then buying all the new parts to rebuild them with, I had ~$650-$700 dollars tied up in it.
A few years ago, a company called CSRP in Austin, TX began reproducing the Granada front disc brake assemblies with all brand new spindles, calipers, etc. Their entire setup is ~ $550 dollars complete.
I would figure up the expense of everything it would cost to get the wrecking yard Granada parts you have back to as-new condition. If it's half or more of the cost of a completely new setup, it would make better sence to buy new. --if for no other reason than your spindles are 32 years old and the ones from CSRP are brand new.
If you do decide to use what you have, it would be a smart move to take the spindles to a machine shop and have them magnaflux-checked for cracks prior to installing them.
What you get in the CSRP kit:
http://www.discbrakeswap.com/image/Granada parts and kit 002 KIT WEB VIEW 80 percent.JPG
CSRP's website:
chepsk8
2,203
Easton, PA
Feb 20, 2008
#10
  • Feb 20, 2008
  • #10
Don't forget the difference in Outer Tie Rod end sizes and tapers, as well as the larger hub diameter.
I did the conversion on my 69 'Vert. I also upped to a Master-Power booster. Prop valve came from the Granada. Worked perfect, thought the Granada Caliper does go "Clunk" on occasion.
yeloxr7
429
#11
  • Feb 22, 2008
  • #11
Under what conditions do you get this "clunk"? I get one in my 69 Cougar with Granada brakes sometimes under hard cornering.
chepsk8
2,203
Easton, PA
Feb 22, 2008
#12
  • Feb 22, 2008
  • #12
It's the way the calipers are mounted. They move a little during braking & backing, so you get the noise. Harmless.
Decurion
353
Livonia, MI
Feb 22, 2008
#13
  • Feb 22, 2008
  • #13
Or if youre missing the anti-rattle hardware like me. Either way, still harmless, if annoying as hell.
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Yesterday at 9:29 PM
2v_johnny
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
K
It's like continuing education
  • Kwerk
  • Sep 3, 2024
  • The Welcome Wagon
The Welcome Wagon Sep 7, 2024
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
