I just purchased a universal 31x19 radiator for my 89 Mustang and wanted to make sure this is the correct size. The inlet and outlets are suppose to be standard Ford. Will my stock hoses work. I know the out lower outlet is angled slightly upward.
Brads Coupe said:When I stepped up to a 3 core aluminum rad they said in the manual it had all the factory connections but the lower rad hose would not work. What we ended up using was a factory rad hose for a 69 Mustang.
Scott W said:I have the griffen "nascar" series rad. It's the one with 1" tubing and no petcock. I was able to use my upper and lower hoses with no problem. The hoses are a bitch to get on, use some silicone spray or something.
Griffen makes a few different kinds of rads, so you may not have the same one as me.
Ford_Racing said:I got my radiator in today. I can't install it because my car is at a guys shop. I see that the lower inlet is at an angle. I hope my new blue hose will fit. Stock wedth is 30" when I measured is and this is a 31". Any input would be appriciated.
