Grinds Into Gear On Hard Shifting
  • Thread starter Thread starter foxbodymike87
  • Start date Start date May 15, 2012
First Prev 2 of 2
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
May 17, 2012
#21
  • May 17, 2012
  • #21
Nik you ever tried just adding friction modifier?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 17, 2012
#22
  • May 17, 2012
  • #22
The Trick Shift is basically Type F transfluid. Type F has friction modifier added to the blend, so I don't doubt it improved shifting. That's why guys who run it in their worn auto's are seeing an improvement as the make the clutches "grab". I don't know what the long term effects are like, but I can't imagine its lubricating and heat control properties are as good as a standard or synthetic ATF fluid though? And Hot shift is a basically a synthetic blend with added friction modifier....so yes, you have run synthetic trans fluid in your T5 and noticed a difference.
I say if it works, use it.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
May 17, 2012
#23
  • May 17, 2012
  • #23
No I haven't. Thoughts?
Why wouldn't it be...? Plus, keep in mind that MTs are much cooler running than ATs, which is really what the fluid was designed for.
Haha, but was it because it's a synthetic blend that caused the difference, or the other additives such as friction modifier that did it? Like I said, I have run synthetic, Mobil 1 actually, and did not see a discernible difference.
srtthis
5,129
1,666
204
Maryland
May 17, 2012
#24
  • May 17, 2012
  • #24
ive used it back when i worked on the 03/04 cobra's a lot since a lot of people didnt like how notchy the T56 was. it worked wonders.
gearheadboy
1,425
177
84
Greencastle Pa
May 18, 2012
#25
  • May 18, 2012
  • #25
I disagree. A good synthetic ATF fluid can make grinding between gears disappear if the synchro's aren't too far gone. Been there, done that. Ran Mobil 1 synthetic ATF in my last Mustang and the grinding went away.
I just had my T5 rebuilt by Hanlon Motorsports. It shifts like smooooothe. I run standard ATF per his advice. The rational is that most newer kits have teflon or carbon fiber blocker rings. The synthetic is too slippery for them to grab the next gear and spin it up to speed to mesh well when shifting fast. So provided your rebuild was correctly done (nothing missed) and you have a new style kit, I'd be inclined to try the standard ATF. Mine works awesome.
First Prev 2 of 2
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
H
Transmission Help
  • Harman78
  • Feb 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 21, 2025
Harman78
H
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
R
2005 V6 manual shift issue
  • Rrf
  • Aug 28, 2023
  • 2005 - 2009 Specific Tech
2K
2005 - 2009 Specific Tech Aug 29, 2023
Dino Dino Bambino
J
  • JRC99
  • Apr 19, 2025
JRC99
J
