Ground effects Removal
  • Thread starter Thread starter backfocus
  • Start date Start date Feb 7, 2006
backfocus
254
Little Rock, AR
Feb 7, 2006
  • Feb 7, 2006
Was wondering what is best way to take off my ground effects. I have Xenon's that were installed on my LX when I bought it. I don't know who put them on but the used some sort of black epoxy every 10 inches or so. Is there a special knife to cut this stuff with or a better way to go. I want to save the pieces to be reused after I do some body work the the fenders and undercarriage. Suggestions.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Feb 7, 2006
  • Feb 7, 2006
Oh hell, they glued it on? Thats what happens when ricers get ahold of a mustang. They brutalize it.
You could try some chemicals that remove sticky stuff, such as goof off, but I doubt that will do it. If you have a heat gun try seeing if that will soften the crap, if it does then get it hot and it should come off. A soft scraper should be a valuable tool. If you have to, butcher the kit to get if off. That way it's off the car and it can't be used again to deface another mustang.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 7, 2006
  • Feb 7, 2006
Without seeing exactly how it's attached (the epoxy used), it'd be hard to say, but you might be able to use a heat gun, and some sort of knife like you suggested to break the bond.
BlownFiveLiter
18
108
Chicagoland
Feb 7, 2006
  • Feb 7, 2006
Grr... 5 minutes late on that one. That'll teach me to open up several windows at once! At least we're thinking on the same level
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
Paint and Body Frame rail dimensions
  • keel
  • Jan 30, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 13, 2026
keel
  • dan50
  • Jul 18, 2026
dan50
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
