Grounding Question
  • Thread starter Thread starter mkk50
  • Start date Start date Apr 19, 2006
M
mkk50
109
29
39
Apr 19, 2006
  • Apr 19, 2006
Ok, im still playing with my high idle, its around 1k ish, and today i was testing the tps, and if i ground it to something in the engine bay, it reads around .98 volts, but if i ground it to the black wire on the tps, it reads about .76 volts.
Is that a sign of a bad computer/engine ground? Or maybe even a bad tps?
Also, anyone with an autometer tach, when you turn the key on, does it go to zero? cause mine goes to like 150 - 200 and stops.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 19, 2006
  • Apr 19, 2006
Grounds are important to any electrical system, and especially to
computers.
1.) The main power ground is from engine block to battery: it is
the power ground for the starter & alternator.
2.) The secondary power ground is between the back of the
intake manifold and the driver's side firewall. It is often missing or
loose. It supplies ground for the alternator, A/C compressor
clutch and other electrical accessories such as the gauges.
Any car that has a 3G alternator needs a 4 gauge ground wire
running from the block to the chassis ground where the battery
pigtail ground connects.
The 3G has a 130 amp capacity, so
you wire the power side with 4 gauge wire. It stands to reason
that the ground side handles just a much current, so it needs to
be 4 gauge too.
Picture courtesy timewarped1972
3.) The computer has its own dedicated power ground that
comes off the ground pigtail on the battery ground wire. Due to
it's proximity to the battery, it may become corroded by acid
fumes from the battery. It is a black cylinder about 2 1/2" long
by 1" diameter with a black/lt green wire.You'll find it up next to
the starter solenoid where the wire goes into the wiring harness
4.) All the sensors have a common separate ground. This
includes the TPS, ACT, EGE, BAP, & VSS sensors.
5.) The O2 sensor heaters have their own ground (HEGO ground)
coming from the computer. This is different and separate from
the O2 sensor ground. It is in the fuel injector wiring harness and
comes out under the throttle body. It gets connected to a
manifold or head bolt.
6.) The TFI module has 2 grounds: one for the foil shield around
the wires and another for the module itself. The TFI module
ground terminates inside the computer.
7.) The computer takes the shield ground for the TFI module and
runs it from pin 20 to the chassis near the computer.
8.) The computer's main power ground (the one that comes from
the battery ground wire) uses pins 40 & 60 for all the things it
controls internally.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103#volt
for help troubleshooting voltage drops across grounds
Extra grounds are like the reserve parachute for a sky diver.
If the main one fails, there is always your reserve.
The best plan is to have all the grounds meet at one central spot
and connect together there. That eliminates any voltage drops
from grounds connected at different places. A voltage drop
between the computer ground and the alternator power ground will effectively
reduce the voltage available to the computer by the amount of the drop.
M
mkk50
109
29
39
Apr 19, 2006
  • Apr 19, 2006
thanks, ill check the ground behind the intake, i know ive seen it there, ill make sure its tight tho, and ill look for the ground for the sensors. I cleaned the computers ground already.
Im sure glad i bought the shop manual
R
93 LX 2.3 Trouble codes 53, 85, 21 help
  • Rickshaw302
  • Apr 15, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 18, 2025
AeroCoupe
A
Resolved Fuel Pump issue - test port jumped comes on (87 LX)
  • afjLX
  • Nov 16, 2024
3K
Fox 5.0 Mustang Tech Nov 26, 2024
afjLX
A
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
