Update: This thread started as a hunt across the fox market that led to an amazing fox. I really like the search & story, and I'm going to keep it going as the progress thread.
So, I can't begin to describe how much fun I've had with the ol' '93 over the last months. It's been out and about in the Monterey area, and it's getting attention! Just today, I went to pick up some parts from the store driving my Saturn, and when the guy at the counter asked for the model, he asked to see a picture. He recognized it immediately and said he'd seen me around before. Another time, a guy started telling me about this beautiful blue fox he'd seen around with True Forged wheels, and I got excited because, lol, I didn't realize he was talking about my car. I finally figured it out and when he said he hadn't met the guy yet, I shook his hand and introduced myself
. At a fun ford weekend at Sacramento Raceway Park, -->
Link <-- at least 2 guys asked me if the car came out of Idaho without being prompted! Wow! They'd known the car and Joe long before and recognized it clearly.
Now, I never was big on taking pics of the old black '91, but then it's just not as photogenic as the '93. I've taken a few. Here's my favorite one of the car since I've had it:
The car has gone to a dragstrip once to a fun ford weekend event in Sacremento where it ran a best of
[email protected] mph @ 12-13psi. It doesn't 60' well, but 29mph in the back half ain't too bad! The 60' might come down a bit with seat time and when I replace these pretty old (I gather) ET Street SS tires with a fresh set (soon). It also outran a powershifted hellcat challenger from a roll on a highway. If you'd like to read about a little action, you can check that out over on the SVT forums. I'll post links, but will also remove them if this is a TOS violation; apologies if so:
Blown S197 &
Several others.
Now as far as progress goes, I haven't had to do too much, though tuning's been a bear. I've easily spent 80+ hours tuning, learning to tune, coding a program in python to tune, adjusting, tweeking, etc... but I've thoroughly enjoyed that part.
Primarily I've learned a ton about tuning, thanks a bunch to Steve
@a91what and have gotten the car running pretty nicely on 91 octane, whereas it was previously running on E85. Now, I'm not a pro and there are still some things I wish I could figure out. For example, I don't like how it spikes lean between gears, but they are so sharp and by the time I'm back in gear AFR is back where it should be. Cold idle is stable, but a bit finicky. I'm playing some tricks to keep the car from stumbling on initial acceleration. But, all in all, I think most people would be pretty thrilled with its driveability on the street, especially considering what it is. When it's warm, it feels/drives almost stock.
Today, I wanted to add a couple of recent adjustments. I've had an issue with belt squeal. The old alternator bracket was the sliding bolt kind:
And, perhaps there's a straight forward way to ensure good tension, but I found belt adjustments to be a 2-man job. So, I swapped over to an adjustment rod setup that makes doing it alone a lot easier and I can progressively increase or decrease tension if there's still squeal:
I also went to a Continental 4060457 45.7" belt that has the same design as the old goodyear gatorback belts:
Right before these adjustments (after I'd ordered the parts), a powersteering pump bolt backed out to the point that it hit the pulley, and I hope that explains why I lost the outer most (radiator side) rib on the original belt. There's still a bit of squeal when I rev the engine and it's still cold, but I hope it's just a matter of increasing tension.
I've also noticed some inconsistency in boost pressure. It seemed to spike early and drop off significantly. I've seriously noticed it jump on initial spool as high as 14 psi and drop off to less than 8 by the end of the run on my datalogs. Also, when I adjusted the Eboost2's set point, it took huge changes to get modest differences until suddenly going from 72 to 73 resultsd in overboost at 16+ psi. That's scary on 91 octane, but I'd tuned 8* safety timing and very rich on fuel if I ever went higher than 15. I started thinking that the spring in my wastegate was too light @ perhaps 6-7 psi, plus it didn't quite look right to me. I thought maybe it was one of my old BOV springs or something. So, I bought a complete set of Tial Wastegate springs and popped a 10 psi spring in today. On the first drive with the Eboost2 set to 0, I mashed it, and got out of it as I heard it spool... F#%$! 16.7 psi! Wow. I'm glad I got out of that immediately. I pulled out the manual and found that the wastegate solenoid was plumbed to the wrong ports! whew. That's a relief. I re-plumbed it, and on the next drive, boost shot to 11.4 psi and then settled in the 10.4-ish range dropping no lower than 10.1. Much better! Hopefully, I'll see similarly smooth levels as I adjust the EBC. I plan to run a 12psi setting and a 14psi setting for 93 octane. I'll go beyond those on race fuel, of course. New plumbing job pics in next post:
