Man it is good to see the ole bucket getting some love. still looks great, at least to me
-eating grin crawls across your face and the feeling in the pit of your stomach "pings" just once (hope I don't get a ticket), you're satisfied that you still made the right decision.
I read it, and so far as I can see, that's 100% the way it's plumbed.Scroll down to 3) here:
FAQs
Discover Aeromotive’s superior fuel systems, where cutting-edge aerospace engineering meets automotive passion. Explore our range of high-performance fuel pumps, filters, and regulators, designed for reliability and efficiency at any speed, any angle, or any condition.aeromotiveinc.com
They do not get into the math but I trust Aeromotive as they build quality pumps, rails, and regulators.
Dual rail applications should employ a Y-block to split the supply line before entering the rails, then individual lines are run from the opposite end of each rail into each inlet port on the regulator.
Replying to me? I'm pretty sure you were the source of the info. Was it the injectors that were tapping out & the reason they backed the tune down to 935? In any case, as I have the Weldon 2025 on my other car, I'm aware that at higher voltage it can support more. 120 injectors might have been the culprit, but figured they'd definitely support more. Frankly, the pump is good for higher voltage & the injectors will flow a ton more with another 10psi. I really think there's plenty of fuel system for an even bigger turbo, which I will probably do in time on my other car. However, 'Grover' is going to be street focused, as that's what its suspension calls for. 600-700 rwhp is way more than enough for this car, and everything on the car is over-engineered for that power level.The car has a Weldon 2035 on it, has plenty of pump.
it... done with them. Maybe try the RXT or some other brand of clutch.
ing car to Foxtoberfest, this year. I do not want to blow the damned thing up or run into any issue that may prevent that goal. So, what's the point of pushing it on the dyno before the show?
ing care as long as the long block is right. He did a solid job building the short block on my other car. I'm sure he did a fine job of it again with this engine. That's what I really needed. I'll do what I can with him to get it driving around on the street, when he delivers it. Then later, I'll be careful tuning &/or hire a pro after Foxtoberfest to get it done right.
afterwards.... missing & bucking. Basically undriveable... obviously stressful to us both, though I think with a little bourbon & wine on tap, we handled it pretty well.
