GT-40 intake holding my back??
GT-40 intake holding me back??
Hey guys I need some advice, I have a N/A 331 with AFR 185s, comp cam xe274 .555/.565, 70mm tb, 76 ma/ 24#, 1 5/8 LT headers, 3.73 gears, and a gt-40 intake match ported to the heads. A friend of mine told me that the gt-40 intake was holding back some hp. He suggested a holly systemax 2 or a RPM 2. I dont have the dyno numbers, but the car ran a [email protected] / 1.67 60' on et streets with stock suspension except eibach drag launch kit @ 1200', I shift at 6000rpm. Do you guys think this is true, would I run faster with a different intake. I thought the gt-40 intake was good to around 400-450fwhp. Any advice would be great, Thanks.
dude, our setups are similar...very similar. however, i run 1 sec slower and -8mph... my car must be f'ed up. I am getting 185s this winter and most likely an RPM2 intake.
anyway. yeah, i would opt for the systemax or the RPM/RPM2 for you option. Not sure what RPM range the gt40 likes, but RPM is a great one and RPM2 made like 10 more hp over the RPM in a 5.0 mag shootout.
Like I said on MW, it IS holding you back. Look no further than a TFS R intake for that engine.
N8Miller, something is very wrong with your combination. Dont go swapping parts, find the cause of the problem. You should be running around 113mph with that mild 331. Ever dyno it? Whats the timing at? I'd fix the problem before spending $1300 on a set of heads only to not see much of a difference.
PM me to discuss possible solutions/causes.... thanks
I would choose the RPM 2...obviously the GT40 isn't holding you back to much...but with the added "torque" of the 331 you don't need a "torque" intake...but don't over do it on the intake...RPM 2 is what I think...
There was just an article about this in a recent 5.0 and super fords mag! They dyno tested this guys car with a cobra intake, and then with Holley Systemax 2 and the Holley made 52 HP. Not sure if that was rear wheel power or not but still 52 is a lot. This guy was supercharged and everything. I think you are right on your limit with the GT40. The article said they are good to 450hp flywheel, and then then start to become restrictive. I would suggest the Holley. Ive seen the runners on those things and the Cobra and GT 40 Runners pale in comparison.
