u can also cut the tube apart, use to 2 fitting on the ends and buy some soft copper 5/8" tubing and bend it to fit and then flare the ends, basically making a new egr tube. i decided to just do the 93 style throttle body conversion, so ill be running internal egr. much easier than external if you ask me, although it will probably generate a little more heat.
