Well tomorrow I will be done with my car, and have it back on the road as my daily driver. I just put a complete 1995 cobra motor and transmission. I also swapped the eintire wiring harness, and ecu. What I am wondering is what kind of real world gains will I have over a stock GT. and will modifications on this moter net the same results as on a GT.
List of mods:
1995 GTS
complete cobra motor (intake manifold to oilpan)
cobra ecu
65mm throttlebody
K&N Fipk
Bassani o/r x-pipe
bassani catback
walbro 255lph pump
Fluidyne radiator
QA-1 Tubular front suspension (custom reinforced for strength)
all egr and emmisions eliminated
steeda tri-ax shifter
Cobra R front brakes (brembo 4 piston)
Cobra rear brakes
373 gears
Detroit Locker diff
alloy driveshaft
and some other stuff I cant remember.
It was amazing what all parts I found in my workshop.
I am just wondering if these mods will net a reasonably quick car
List of mods:
1995 GTS
cobra ecu
65mm throttlebody
K&N Fipk
Bassani o/r x-pipe
bassani catback
walbro 255lph pump
Fluidyne radiator
Cobra rear brakes
373 gears
Detroit Locker diff
alloy driveshaft
You should run even with most 94-95 Cobras now. Mid-High 13's with your mods assuming you can hook.
