i picked up a gt40 ( tubular)intake for a rediculous price ( $100 upper and lower). the only thing done to the engine right now is a full exhaust. is it worth the time to put the intake on now, or should i wait until i do the cam?
Yup, if I still had my stock intake, I also do the swap!notchback said:it will gain nothing...but look great.
i'd do it.....
in order to have more air you need more fuel so i recomend you with the intake a larger maff and some 24's...blackstangt said:put it on, upgrade the tb and egr as well as mass air meter, then it will make a nice difference.
blackice said:Personally i wouldnt do an intake , money can be spent in better areas as said in above responses. If i had an AOD i would do a torque converter , if I had a Stick I would doe gears..
aleborjas said:in order to have more air you need more fuel so i recomend you with the intake a larger maff and some 24's...
Blackstangt how does the intake work and what rwhp does your car has?
