I'm trying to track down some info on this engine since its what I plan on installing in my 66(someone stole my original planned engine if you can believe it) first off what is the HP rating from an 01 explorer? am I right to assume its going to be in the 250HP range? This engine runs off a trigger wheel on the crank, rather than a distributor(it has a camshaft position sensor in its place from how it looks) the information I am mainly looking for is to see if I can find out if its a 28.8oz or 50oz balance(or even nuetral) I'll be using an 01 T5 from a v6 mustang(its WC rated at 300ft/lb and will bolt up)
Really if you take a close look at the Stang's tubular manifolds, they're not a whole lot better. Every tube is crimped to **** at the port for bolt clearance.
