GT40 upper with Explorer lower...help please
a1yola
I am in the process of swapping out a GT-40 lower intake for an explorer intake. I noticed that the explorer lower had 2 bolt-holes in it that the GT40 lower did not have, so I simply used brass fitting to cover them...is that okay?
My main problem is that the GT40 upper and lower have an exhaust port running through the middle where the two mount onto eachother, but the explorer intake does not have it. If I install the GT40 upper with the exhaust port onto the Explorer intake without the exhaust port, will this cause a problem? I was told that it may affect the smog, but I am not concerned about that...I just want it to run right.
Please let me know if I can proceed with this swap...thanks :patriot:
Here is the bottom of the upper manifold. Notice the small 9th hole in the center where it mounts:
Here is the GT40 lower...notice the small 9th hole in the center on the mounting surface:
Now here is the Explorer lower...NO small 9th hole in the center of the mounting surface:
hey, 1st off i'm not quite sure why your swapping lowers. The gt-40 and the explorer LOWERS are the same. The hole in the middle is for the Internal EGR setup that foxes use. EGR recirculates exhaust gas back up through the intake manifold. Some people say they they've experienced part-throttle pinging and a small decrease in gas milage.
i didn't know if the egr port would be open when I bought my intake, so I looked into it. It's basically the same thing as not running the egr. So you'll have to get a new computer or somehow trick the computer into thinking the egr is still functioning. Search the forums here and you'll find examples of what other people have done.
Im doing this swap because the original GT40 lower that was in the car was too heavily ported for the stock heads. The previous owner installed thinking it would work fine, but it didnt...and he never got around to swapping back to a non-ported lower. So i was able to purchase an explorer lower locally, but discovered that the hole is in the GT40 upper, but not the Explorer lower. I understand thae people usually do not mis-match explorer and GT40 upper/lower intakes, but this is all i could find.
My main question is...can I safely run this lower on the car using the GT40 upper? Any effects? THanks for the help, I jst want to finish the install:(
I would think you can run it either way. Usually, when buying gaskets they ask you if you want EGR ports or not. They sell kits with EGR plugs, some are solid and some have holes in them. I have blocked EGR before on stock applications, and it was fine.
so if i run this setup and use the GT40 gasket (with the hole for the EGR port), will it cause a leak or anything? Should I buy the gasket and/or plug if my upper has the hole and the lower does not?
YOu have given me the best news so far:flag:
If the upper has the hole and the lower doesn't it woun't matter if the gasket has that hole or not. I believe that all of them do have it. Even if the hole is there, the rest of the gasket seals that area if the intakes do not have the EGR port.
I finally finished teh install and it seems to be fine. The cra definitely idles a lot smoother than before. I havent gotten to really test drive it yet because its raining out here, but hopefully it runs stronger than before.
thanks for all the help and advice:SNSign:
