GT40P spring# with E303 Cam?
  • Thread starter Thread starter Jeff S.
  • Start date Start date Feb 11, 2009
J
Jeff S.
Bismarck, ND
Feb 11, 2009
  • Feb 11, 2009
I have a 1999 5.0 with the gt40p heads and I'm putting an e303 cam in and I need the correct spring # that some of you have run. I talked to crane and they told me kit #44308-1(99841-16 springs and 99942-16 retainers). Anyone use these? Any other spring #'s that will work?
P
phutch11
328
Feb 11, 2009
  • Feb 11, 2009
Call frpp for the spring they recommend for the e-cam - I can't recall the part number.
I've got a used set if you're interested - pm me.
Good luck...
Posted via Mobile Device
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Feb 11, 2009
  • Feb 11, 2009
I had a similar question
GT-40P heads - upgraded valve springs?? - Corral Forums
F
foxbdy88
14
  • Feb 11, 2009
That thread is turning into to a very informative debate. I myself will be going with the Crane Cams spring kit
V
v8only
2,378
22
49
Feb 12, 2009
  • Feb 12, 2009
tfs valve sprint kit. cheap and the most common spring set for the gt40 head swap.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
T
Resolved No run or idle
  • Thebluefox1
  • Oct 10, 2025
Fox 5.0 Mustang Tech Nov 25, 2025
DadLife0724
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
