Gt500 Throttle Body Upgrade
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
what are your thoughts on this upgrade? the throttle body is like 130 bucks and the adapter plate is about 90.
there isnt a ton written about exactly WHY the adapter plate is needed. the only thing i can find is that the adapter plate "perfectly centers" the TB in the TB bores of the intake... im thinking about just buying a new GT500 TB and trying to bolt it onto the car...
has anyone done this?
I designed my own adapter plate. Its made out of aluminum but is only 3/16 inch thick, not 1/2 inch thick like the BBK adapter. My car has a decorator cover over the manifold and if you use the 1/2 inch plate you have to toss the cover which is $90 in value, I wanted to keep that cover so I did my own measuring and found I could make an adapter plate that would allow the butterflies of the throttle body to open fully and keep my manifold cover as well. I have had mine on my car now for over a year without any issues. I also will say the GT500 throttle body is the best way to go, its a plug and play, it works with the current computer on board, and there is no adjustments to be made, except to have a new tune for the new throttle body. I read somewhere someone said that you do not get any gains from a throttle body, well that might be true when your engine is in the stock tune, but you get a race tune and that throttle body lets the gorilla out...not to mention with a CAI combination it really wakes the engine up...
