wow sounds like this has turned it to quite the intersting topic, but i figured i would through my 02. cents in anyway. Both cars are totally in a league of there own, the new Z06 is just nuts, i mean looks at the times the thing posted at the nurberg in in germany, i believe it had one of the best times for the track, beating porshe's and etc hands down, and yes it maybe 10-15 grand more in the price deptartment, but i think the car is a more all around car than the GT500, and just think this is a NA car, granted its 7 liters but hey look at what ligenfelter did with it after they got there hands on it.
Lingenfelter Performance Engineering (LPE) 2005 Chevrolet Corvette C6 Twin-Turbo 427
www.lingenfelter.com
260/724-2552
427 c.i. (7.0L) Twin-Turbo V-8 engine (725 HP)
Original engine removal, inspection, and disassembly
GM 7.0L aluminum block
4340 forged steel crankshaft
Custom forged aluminum pistons
Forged steel connecting rods
Computer balanced rotating assembly
LPE CNC-porting and hand polishing of cylinder heads
2.02-inch intake/1.57-inch exhaust valves
Custom double valve springs with titanium retainers
LPE hydraulic roller camshaft and lifters
Two Garret hybrid GT-series ball-bearing turbochargers
High efficiency liquid-to-air charge cooler
High efficiency liquid-to-air heat exchanger, pump, and coolant tank
Custom molded silicone air ducts
Custom stainless-steel exhaust manifolds
Custom stainless-steel turbo outlet adapters
LPE belt-driven turbocharger scavenge pump and oil reservoir
Conical air filters, heat shields, and stainless-steel clamps
LPE MAF sensor
High capacity fuel system
Oversized fuel injectors
LPE rear mount battery system
Corsa 2.5-inch diameter stainless-steel cat-back dual exhaust system
Professional installation, tuning, and dyno testing
LPE Twin-Turbo Engine Package (installed): $52,995
Engine/Tranny/Safety Upgrades (1,100 HP)
Custom Moldex billet steel crankshaft
Billet steel connecting rods
Heavy-duty timing chain set
FAST intake manifold
Upgraded fuel injectors and support electronics
Secondary fuel pump system
High-flow fuel rails with adjustable fuel pressure regulator
Custom Corsa 3-inch diameter stainless-steel exhaust system
TiAL blow-off valves
TiAL external waste gates
LPE custom dry sump oil system
Custom GT35R ball-bearing turbochargers (special water cooled turbos)
Custom stainless-steel exhaust manifolds and outlets
Higher capacity intercooler with remote rear-mounted coolant tank
Electronic boost controller
Transmission overhaul including H-D main shaft and gear sets
3.15:1 rearend differential gear set
Heavy-duty differential output shafts
McLeod dual-disk clutch with sintered iron disks
Clutch scattershield with transmission safety blanket
6-point roll bar with removable side door bars
Recaro racing seats
5-point racing seat belt system
Boost gauge with gauge pod
Shift light
Fire extinguisher
Video camera mount
1,100 HP Upgrades (installed): $94,500
Additional Upgrades
DRM/Bilstein coil-over shocks/springs
Special anti-roll bar end links
HRE 844R 19x10-inch (front) and 20x12.5-inch (rear) forged aluminum wheels
Michelin Pilot Sport 2 285/35ZR19 (front) and 335/30ZR20 (rear) tires
Chevrolet Z06 front and rear fenders, front fascia, painting, installation
Labor to modify vehicle for oversized wheels/tires
Brembo 4-piston calipers, 14-inch diameter 2-piece, cross-drilled rotors, heavy-duty brake pads, stainless-steel brake lines (front and rear)
Innovative Motorsports air/fuel meter and data acquisition system
LPE additional upgrades (installed): $29,935.99
Total Upgrades Price: $177,430 (Not including vehicle)
Total Package Price: $225,860 (Including $48,430 Corvette C6)
so to say that the GT500 with just a few bolt ons will be able to destroy the Z06 and Viper, i mean the ligenfelter and the henessey viper are on the rarer side but i just do not see anybody comming close to what these companies have done with the vette and viper even in there "tuned down" packages, And yes i also belive that ford was worried to much about making money on this car rather than, trying to devleop and test new things, i mean develop and lighter motor, work with the suspension, etc etc etc. and there is what i think is wrong with automakers today, i mean take some time to throughly develop things, dont just shove it out there trying to make the quick dollar, and improve as years go on, i mean this should have been one of those 1-2 year "special editions" like the anniversary ta's and etc, but people will find alot of flaws in it and i dont think after a few years of production it will have the same luster. so in short to say i would own one yes i would but to compare to a Z06 or viper or of the like i think is a little over the top.
