Guess the mystery parts in my oil pan!
2bav8
2,511
59
Mesa, AZ
www.geocities.com
Took the oil pan off today to fix a leak and of course everything went smoothly until I found these in the oil pan:
I "think" I know where they came from...
and if I'm right no harm done.
Just to get a size perspective, both parts could sit on top of a penny.
Any one want to guess where they came from? :cheers:
12sec67 said:
good guess! :cheers:
yep that's my bet to. i've actually had one fall out on me before too, but it just kind of sat there in the valve cover and i found it changing the VC gasket
if you need that baffle in thereto keep the oil out of the PCV, you can loctite them back in, provided it wasn't a roccker arm that beat them out.
Hack said:
On a Cleveland, there are little fasteners like that, they hold the "turkey pan" under the intake. Does a 302 have them?
Do I win? :D
A stock351C does not have what you describe. The "turkey pan" is part of the thin metal one-piece intake gadket.
2bav8 said:
Correct Answer:
Intake baffle studs!
I had to manipulate them to fit over my roller rocker arms, and apparently a little too much...
Uhh..
Do you mean valve cover baffle? I've never heard of anyone running into intake-rocker arm clearance problems before.
