Guess the Weight of my Car!
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
I am hoping for 2600lbs or less. How close am I and/or what will get me there. I am really trying to get my car really light but keep it streetable and I don't want it to be a ragged out race car with headlights either, so I can't completly gut it. However, I'm trying ride that line. It's far from togeather, but this is what's in line right now, and what do you think the weight is going to be with this setup.
Complete Deletes (no replacments)
Front Bumper w/ Shocks
Fog Lamps w/ Lamp Support Bracket
Side mouldings
Airbag System w/.Bracketing & Sensors
Hood Prop
Hood Latch Assembly w/ cable w/switch
Washer bottle
Evap Cannister
Front Swaybar
P/S System
Smog System
A/C System
HVAC unit under dash
Stereo system w/speakers
Cruise Controll System
Sound Insulation Material Deleted (from firewall to hatch)
Rear Seat w/all Bracketing and Belts
Sub-brackets on Dash Support Frame
Center Counsil Supports
Differential Dampener
Padding under carpet and hatch
Quad Shocks and Brackets
Spare tire and jack
Rear Bumper w/shocks
Quad Shocks w/brackets
Tailpipes
Lightweight Replacments: (replaced with lighter components)
Alumimum Heads
Alumimum Pullies
Front Coil Over Conversion
Tubular K-Member
Tubular A-arms
Catless Mid-pipe
Alumimum Driveshaft
Weld Wheels (15x3.5 & 15x8)
Drag bucket seats
LX trim.
Heavyweight Replacments
Alumimum Radiator (lighter empty but holds more coolant reversing reduction)
TKO 500 Trans
Upper and Lower Control arms
Larger battery
Adds weight:
Oil Cooler:
MM Full Length Subframes
Battery relocation unit
Driveshaft Loop
So what do you think?
I don't know if you will get to the 2600lbs, but you will be close. Some of the things you have on the list weigh a ton, but then you will be adding weight with some of the other things. Good luck :nice:
If the car doesn't weigh under 2600lbs no driver i would be surprised.
My car weighs 2800lbs with me weighing 155lbs. so 2645lbs.
This is with 5 gal fuel and exactly everything you have done with the exeption of
hood prop and latch assy.
side mouldings
dash support frame
center console supports
quad shocks w/brackets
tailpipes
rear seat
replacements:
Don't have.
Tubular K-Member
Tubular A-arms
LX trim
I have a c-4 instead. The rest is all the same. I have been to two scales one at a local drag strip and one at the local recyling center. They were 50lbs. difference. 2800-2850
You have to have met your goal. :nice:
Hey man, I don't know how much your car would weight, but I got a question for ya. How hard is it to turn without the PS system? I'm contemplating deleting mine...
If you don't drain the fluid or at least bypass the pump then you have to push it through the pump which is much harder. On skinnies it's a lot easier.
P.S. I forgot that I also have a Fiberglass hood. :doh:
I would do that but the car isn't running right now, in fact it's in pieces and I am just wondering because if I'm going to delete things or make major changes, now is the time. I plan on a fiberglass hatch with a speedglass rear window. My windshield is pitted pretty bad and since a replacment will cost about the same in glass or speedglass, I'll probally go with speedglass I'll probally do fiberglass doors with manual windows before I paint it. I am not sure if fiberglass fenders would really be that much lighter. Well, at least I'm in the area. :nice:
I have a flaming river rack and it was well worth the money. I my car with the factory rack for a while and it was like night and day difference.
Sounds like you have the diet thing down pat.
My 82 hatch weighed 2705 without me, a year ago, with about half a tank. This is still with aluminum bumpers and a non ac heater. All stock sheetmetal and doors, stock front seats only. No carpet, sound deadener. Has a ds loop and subframes.
I also decided to go manual brakes, that has to be good for another 5-8lbs. I copied all that from a wordsheet I have saved on the computer. I am asking because I plan on a custom cam, and one factor is weight. I also plan on running a little 306.
I wish I bought a coupe in the first place. Oh well, I guess I'll have to resort to the fiberglass hatch and speedglass window. Trying to think of more ways to reduce weight, or do I pretty much have everything down?
Don't forget the weight you will/can shave off the engine.
If you ditch the EFI and go carb that'll save weight in the manifold and the associated wiring. And aluminum heads will save a significant amount of weight too.
Will this car see street duty? Will it have to pass emissions?
You could save at least 5 or 10 lbs with a dry cell, but smaller battery too.
How crazy are you gonna go? You can buy all lightweight engine internals, crank, rods, pistons, flywheel.....and the grand daddy of light weight engine weight savings an aluminum block from Dart or FRPP. There lighter and stronger.
Just an aluminum block will save about 60 lbs. That with heads and a carb intake will cover well over 100 lbs shaved off. Add the lightweight battery, and EFI wiring delete and Emissions stuff you can dump and you'll get anohter 50 lbs dropped I think.
Alright, I removed the stock K-member and A-arms. I can pick the front of the car off the jackstands by myself, and I'm no hulk. Yeah, nothing under the hood but still. I think I'm done with this weight reduction frenzy, in fact I think it's time to start putting this car back togeather. Everytime I start putting it back togeather, I end up tearing it back apart for some reason, but now I can't think of anything. The feeling "it's ready" is finally starting to come to me, it's about time.
I think I'm going to just put the flat tappet 306 in the car. I wanted 11:1 compression and pistons more suited for TFS heads but oh well, I'll just save the money towards something else and settle for 9.8:1 or so. Maby a turbocharger would fill in the extra space and make up for the lack of cubes. I still don't quite know what to do about the intake and such, I'll figure that out as I go. Right now I'm just going to try to get the trim primed and set on the chassis, a working interior, and the car ready for a motor. I want the FR manual rack system, but that may have to wait, I don't know. Definatly a custom cam. Maby an electric WP as well. Then I'll be able to get back into the racing seat.
