Gutting the Mach 460 in a 2003
Aquarius
28
Hey guys,
This weekend I'll be attempting the install of my new sound system. I have a 2003 GT with the Mach 460 and I'll be removing it completely. I'll be replacing it with a Pioneer Avic D3x h/u, 6.5" Infinity Kappa components in the doors, 6x8" Infinity Kappas in the rear deck. The speakers will be powered from an 4-channel Alpine F450 amp and I'm also going to add my 10" MTX Sledgehammer sub powered by a MTX TA4252 amp.
Here are my questions:
Where can I find a wiring diagram for the 2003 GT Mach 460?
While I'll be removing the stock h/u, speakers and amplifiers, am I better off just leaving the stock wires in there in case I ever want to put it back in? As opposed to ripping them out? I plan to rewire everything.
What's the best way to route the wires? I plan on mounting both amps to the rear fold down seats but I'll have to run wires into the doors for the front speakers.
Anybody have hints/suggestions on mounting the new component tweeters in the stock location? I know its not a direct fit so any advice would be greatly appreciated!
Finally when I install the h/u, should I solder the wires from the back of the head unit to the wires coming from the car?
Thanks!
if it were me i would just try to use the existing wires to avoid having to rewire everything, be prepared to remove all interior panels if you are going to remove everything and go with new. Then again i try to avoid anything electrical in a car just my .02 On a second note does your head unit work good and are you willing to get rid of it. let me know
Here is a wiring diagram. I would leave all the factory wiring in there. As far as installing just make sure you run your power wires away from your speaker wires. Running wires in the doors is easy. If your running amps I would replace the wiring it would be kind of a pain to get the amps wired into the factory wiring and the amps need bigger power wires then the stack amps have.
Radio Wiring Diagrams
I replaced everything in my 03 with the Mach system, and have done it many times for other people as well. The way that I do it makes it easy and requires no more work than if it were a non amplified basic system.
Run the amp power wire(s) from the battery (do not connect yet) into a fuseholder then through the firewall on the drivers side, then route the wire to the trunk, also down the drivers side.
Run 3 sets of RCA cables, 4 pairs of speaker wires and a remote turn on wire from the radio location down the passenger side to the trunk area. I always wrap these wires with electrical tape every 10" or so to keep them organized and in a nice bundle. Also, I mark each end of the front RCA with 1 line, rear RCA gets 2 lines, and 3 lines for the sub RCA, so when you are plugging them into the deck and amps you know what cable is what.
Connect the 4 pairs of speaker wires at the radio location to the 4 pairs of speaker wires on the aftermarket wire harness (Metra 70-1771) that plugs into the stock radio plug. These are the wires that would normally be connected to the deck output if you were not using a 4 channel amp.
Connect the remote turn on wire in the bundle at the radio location to the remote turn on lead on the new deck (Blue/white). Connect the 3 sets of RCA cables to the proper outputs on the new deck. At this point you can complete the deck install.
Next I remove the factory amps and enclosure from the rear deck, and install the new speakers. You MUST connect the new speakers to the factory wires that were connected to the factory tweeters. They will have a gray 2 pin plug with a clip on one side. (the wire closest to the clip is the negative) The rears can be found on top of the rear deck lid, and the fronts can be found just below the factory tweeter behind the door panel. If you are using a component set of speakers in the doors, you will need to find a location to mount the crossovers in/on the door, then extend the factory wires going to the stock tweeter and connect them to the input of the crossover. I always mount the crossover directly behind the armrest of the door panel as there is ample clearance for them.
Run a set of new speaker wires from the woofer output of the crossovers through a hole on the inner door skin and route them to the stock speaker location, making sure to keep them clear of any moving window parts. To properly mount a 5.25" or 6" midrange, I cut a 5 x 7 plate out of ABS plastic using the stock speaker as a template, then cut the proper size hole in the center for the new speaker. Mount the plate to the stock speaker location, connect the new wires to the new speaker and mount the speaker to the plate.
Next, run a new speaker wire from the tweeter output of the crossover up to the stock tweeter location. To mount the new tweeters in the stock location, I use a metal strap, called backstrap at stereo shops, and bend/cut it so it can be mounted to the stock tweeter pod using the factory screw holes that held the stock tweeter in place. Once the backstrap is bent into the proper shape to fit into the tweeter hole, mount the new tweeter to the backstrap using the supplied hardware that came with the new speakers, then mount the tweeter/backstrap assembly to the tweeter pod, running the wire out the bottom. This method will work with any tweeter, but some are easier than others so you may have to get creative. Now mount the tweeter pod back on the door and connect the tweeter wires that come from the crossover to the wires comming out of the tweeter pod.
The rear coaxial type 5 x 7 or 6 x 8 speakers will drop right in to the stock location from the top of the rear deck lid, and remember to connect them to the stock tweeter wires (gray 2 pin plug).
Once all the speakers are installed, mount the amps in the desired location and make all power/ground/remote/RCA connections. Make sure that the amp ground wires are the same guage wire as the power wire, and they should be kept as short as possible and need to grounded together in one common location. Once all those connection are made you will need to hook up the 4 pairs of speaker wires to the 4 channel amp. Using a 9 volt battery or a 12 volt power drill battery touch the positive and negative ends of one of the speaker wires to the terminals of the battery to "pop" the speaker. This will allow you to hear which speaker the wire is connected to so you can connect it to the proper output of the amplifier. Repeat this step for the remaining 3 speaker wires.
At this time you can connect the power cable to the battery, and turn the system on and check to make sure everything is working properly. Set the crossovers on the 4 channel amp to about 80htz high pass, and the sub amp should be set to about 80 htz low pass, and the gains should be set to about half way to start with. Make any final adjustments to get what you think is the best sound.
This may sound like a lot of work, but I've been a MECP certified installer for 13 years and can tell you that it is by far the fastest and easiest way to replace the Mach 460 system. An experieced installer should be able to complete this install in about 3-4 hours. I hope this helps and good luck!!
Also, I never solder wires with the exception of heavy guage remote start wires. Just use a good set of Klien crimpers and proper sized butt connectors.
Could you clarify something on the four pairs of speaker wires?
The way you instructed me to route the wires, four pairs connect at the Metra harness and are run to the trunk where they connect to the 4-channel amp. The respective RCA cable is also connected to that amp.
I'm confused thinking this through. Does the signal get sent form the deck through the RCA's into the four channel amp and then along the 4 sets of speaker wires back to the deck where it goes into the harness and then into the factory wiring to the speakers?
Yes thats the signal path.
You are correct.
Thanks so much for the info - you've given a whole lot more confidence in tackling this project this weekend. A few final questions: so I'll have an amp for the sub and the 4-channel for the speakers. I bought the Rockford Fosgate multi-amp install kit and I also bought a Tsunmai 1.2 Farad capacitor to support my system. Should the amp power cable routed into the trunk first go through the capacitor, then the 4-channel amp, and then the sub amp? And, is it okay to mount the amps and capcacitor to the fold down seats? Should I put a mounting plate on the seat before hand? I don't know what the backing on the seats is so I'm not sure if I can trust it. Thanks so much!
I would run the power wire into the trunk area and then use a distrobution block with 1 input and two outputs. Put the cap right before the distro block (using as short of wires as possibleto connect the two.) then connect the amps on the output side of the distro block.(Once again using as short of wires as possible.) The seat backs are metal, so just use screws designed to hold into metal and dont strip 'em and you'll have no problems. This is how my trunk department turned out, I used a single 5ch amp.
I know this is borderline threadjacking, but I was wondering how you could go about gutting the 460 if you AREN'T using a 4ch amp to power the speakers? I have a mono amp/10 inch woofer and want to power my new 6x8s using the head unit instead of the 460 amps.
Could you just unhook the 4 speaker outs from the metra harness and run them straight from the head unit to the speakers, bypassing all the factory speaker wiring? The factory harness would be used for power, switched, and ground. remote and speakers would be run by me to the amp and speakers. If that's how you do it, then do I still have to hook up the factory tweeter wires as described above?
If you run new wires from the deck to all the speakers then you don't have to do anything with stock tweeter wires at all. If you have the newer Mach system with the stock double din radio,(2002 - 2004 I think) you can hook the new speakers up to the stock tweeter wires and wire the Metra harness normally and everything will work fine without the need to run new wires. Much easier IMO.
I've got the older mach with the slave cd player. the wiring has been hacked/put back together in the back, and I'd rather just bypass it and run some new wires. There are some popping/sound quality issues that I believe are caused by the wiring screwups.
I had that setup in my '99 Cobra, I have since completely replaced the factory stuff. I did however use the factory wiring. If you run the factory speakers off of an aftermarket sterio with the amps bypassed, you will need some type of crossover network to get the best sound. The factory amps had the crossovers built in, so if you bypass 'em...
