Guys check out my compression test results
WhiteDevil
2,717
San Diego
Well the gauge was kinda old, so i might try again with a newer one but, here is what i got right now. Thanks ahead of time. Stock 104k heads
#4. 131 #8. 138
#3. 135 #7. 138
#2. 126 #6. 135
#1. 121 #5. 134
All look good except #'s 1 and 2. You mainly want to see if the numbers are consistant for all cylinders... You might have done somewhing wrong with the first two that you didnt know. The rest look good.
I think its the heads, that are causing the low compression. When i was pressurizing the cylinder to change the valve springs the #1 cylinder you could hear and feel the air leaking back through the intake manifold. Same but not as bad with the #2 cylinder.
You might have communication between cylinders 1 and 2. Try putting a plug in cylinder 2 and testing cylinder 1, and vice versa. If you get higher compression when you do this then you have communication and you need a new head gasket. Also, here's something else to think about. You have 104K on these heads, there's a possibility that some of your valves aren't seating properly.
That would be your valve springs allowing the valves to float. The second time you revved your engine past 5,800 with stock springs it was time to change them. If you keep allowing it to happen you'll start breaking/bending valvetrain parts. I don't think you have any bent valves at this point, or your compression would be much lower on the cylinders in question(like next to nothing). At 104K you definately need new valve springs at the very least. As far as the valve seating goes, all the tests you can perform without taking the heads off are listed I do believe.
