I could pick up a 2000 Explorer longblock for $500 with roughly 60k miles, but I'm curious what all is involved in getting it running in my Mustang. Does my distributor simply drop right in? All my accessories, oil pan, etc will be swapped from my current engine. I'm probably going to put a TFS stage 1 cam in (still looking at others, too) with the set of GT40p heads I already have (going with larger valves, light port work), and could sell the set currently on the engine to offset some of the difference, but just wondering your opinions on how happy/unhappy you guys are with your swap? I have a Typhoon intake ready to go on top, so as far as I know now, I need a new TB, some 24-30lb injectors to match, and get my 75mm Pro-M recalibrated. I also know the question has been beaten to death here, but what kinda power could I expect from this combo? It's not my daily driver anymore, so down the road, a blower may also come into play, as I've seen some halfway decent deals on the Vortech SQ trim for the 94-95's. AFR heads or something are out of the question, as I don't make enough money to support my car fund as much as I'd like, so I'm going the budget route, while still opening the door to a later addition of a blower. My concern there is with the higher compression from the "P" heads, would I be running into detonation problems on 93 octane? Thanks guys!
Matt
Matt
