Are these the correct springs for some AFR 165cc heads?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=CCA-26120-16&N=115&autoview=sku
My cam calls for 130-135 on the seat. These have 155, but they seem to be the right diamter for the application. Any input? I don't really know which ones. Also, do I need locks and retainers? Thanks.
Jake
Summit Racing said:Valve Springs, Single, 1.445 in. Outside Diameter, 130 lbs./in. Rate, 1.230 in. Coil Bind Height
Recommended Camshaft Style Roller hydraulic
Installed Height (in) 1.880 in.
Seat Pressure at Installed Height (lbs) 155 lbs.
Open Height (in) 1.280 in.
Open Pressure (lbs) 377 lbs.
Jake
I need to do that and change the fuel filter and clean the air filter and MAF. I work from 7-3:30 and don't get home until 4:30, so I'm not too motivated in the evening to do anything.
