Man I am syked...Me and my bud Carl started at 8:00 this morning and 12 hours later (8:00pm) we were done with the swap. I did:
Trick Flow Intake w/ 3/8's spacer/EGR elbow
Trick Flow Aluminum Heads
Trick Flow Cam
Timing Chain
New rollers, 1.6rr and push rods
Anderson Fors Motorsports chrome valve covers
70mm throttle body
24lb injectors
75mm Pro-M
255lph Walbro
SCT custom chip
EGR delete
MSD distr and wires
Chrome FMS water neck, and new water pump
Just about every other little thing as well.
It started right up set the timing/fuel pressure and ahe has a nice lobey idle. The only friggin problem we had is the chrome water neck where the thermostat is leaked like 4 times. I finally had to grind the chrome off(which I should have done anyway) on ther gasket side. I drove it about 1/2 an hour tonight and everything is perfect!! Oh well...I will also post some before and after pics later.
Trick Flow Cam
Timing Chain
70mm throttle body
24lb injectors
75mm Pro-M
255lph Walbro
SCT custom chip
EGR delete
MSD distr and wires
