H/C/I swap need advice
daviszx3
42
maryland
i got a stock 90 notch 5speed with a v3 10psi vortech system, with exhaust and 373 gears and no other mods...well i wanna do a head cam and intake swap and need advice what would be a good setup to go with im tryin to stay on the cheap side...but this what i came up with a e303 cam, trick flow track heat intake and 210cc pro comp heads..suggestions welcome please thanks
the f cam wouldnt create and clearence issue's would it? also what injectors tb n mass air would u suggest thanks
My advice measure..you will probally be okay but it's a really good idea to check ptv. what size rockers/springs you going with? It would really not be a good idea to get into the revs on a motor I didn't check out.
