H Pipe Bracket Fab...help
ja1919
91
OK i got a factory h pipe with no hangers...i welded 1/2 in steel rod on the pipe..but does anyone have dimisions of the angle of the bend in the bracket..or the distance between the two pieces..ALSO how much distance should there be between the top of the h pipe and the bottom of the trans cross member support when the pipe is installed...mine looks soo low...ANY DIMISIONS FOR THE BRACKET WILL BE HELPFULL
ALSO DONT POST..."DUDE JUST BUY A NEW H PIPE, PROBLEM SLOVED" CUZ IM NOT
I no longer have my stock H-pipe setup, but I can give you some dimensions off of the X pipe setup I have that is in my car from which ever point you want if it will help you any?
