H Pipe Install Problem! Please HELP!
  • Thread starter Thread starter 88-378
  • Start date Start date Oct 20, 2007
88-378
14
Alpharetta, GA
Oct 20, 2007
  • Oct 20, 2007
I can't get the hangers on the H pipe to reach the tranny mounts. Do i need to lower the tranny? I would like not to bend anything for a good fit.
Maybe taking the driveshaft out would give me the clearance?
samickguy15
404
Delavan, IL
Oct 20, 2007
  • Oct 20, 2007
I would try taking the driveshaft out first. Don't be afraid to bend the mounts on the pipe. Most aftermarket items don't first 100% and generally require a small amount of finess or mods to fit correctly.
U2SLO450
118
  • Oct 21, 2007
put the car on a lift and you can fit it with no problems, mine did the same thing and would drag in some spots because the hangers were'nt fitting right. when i put it on a lift they slid right in
88-378
14
Alpharetta, GA
Oct 21, 2007
  • Oct 21, 2007
I have the rear axle on stands and the front on stands at the frame. If I put the rear on the frame the rear axle will drop causing the driveshaft to as well. then the pipe will still hit the drive shaft.
88-378
14
Alpharetta, GA
Oct 21, 2007
  • Oct 21, 2007
Got the h pipe on the tranny mounts but now it needs to go forward 1/2 inch. I have to grind away a little chunk from the exhaust tranny mounts to get it. should take me another week or so!!!!!
cenok is family
1,409
69
79
Norman, Ok
Oct 21, 2007
  • Oct 21, 2007
man, i haven't used the exhaust mounts at the crossmember on any of the stangs i've ever owned with no problems what so ever. and it makes it easier to install/remove it later.
88-378
14
Alpharetta, GA
Oct 21, 2007
  • Oct 21, 2007
I'm almost their! Beer break!
cenok is family
1,409
69
79
Norman, Ok
Oct 21, 2007
  • Oct 21, 2007
sweet! post some vids when you're done! what headers and mufflers are you running?
88-378
14
Alpharetta, GA
Oct 21, 2007
  • Oct 21, 2007
FRPP headers, Magnaflow catted H, and Magnaflow cat back. All SS.
BYRDPE
1,556
Memphis,Tn.
Oct 21, 2007
#10
  • Oct 21, 2007
  • #10
Ditto...
I cut those suckers off the H-pipe and removed the hanger over 5 years ago.
88-378
14
Alpharetta, GA
Oct 21, 2007
#11
  • Oct 21, 2007
  • #11
It's all in. Just need t line up the cat back. Went well. Yeah right!!!
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
