hard start please help PMS
D ABLO
IM getting very frustrated im new with the pms and need some help. I have a very hard starting problem if i mess with the pms and global fuel i get it to strat some times need a advise and a quick tune thank guys. i think it got alot to do with my injector size.
PMS Series 3
Year model:1991
Engine cubic inch:302
Power Adder/NA: T-76 Hpp
nt of boost/nitrous:10 psi
Intake:TFS street Heat
Throttle Body:70
Mass Air Meter:76mm cal to42lbs injectors blow thru
cyl Head & rockers:AFR 165 61cc 1.6 E-cam
Injector Size:60 lbs
Header size/type:HPP hot side and cold side
Fuel Pump(s):-10 feed -10 return eliminator pump
Supply/Return Line size:aeromotive
fuel type: 93
i got timing at 14 locked out for now. plugs (3923) at .28 and fuel pressure at 42 with vaccum. what do need on the start fuel and global fuel? do i need to back off the timing to 10*? for got to add Digital 6 if that helps. Just a setting to help it start even thanks.
