  • 1994 - 1995 Specific Tech
Hard starting, hesitation, stalling
  • Thread starter Thread starter 95five-oh
  • Start date Start date Apr 30, 2010
9
95five-oh
158
Mount Airy, MD
Apr 30, 2010
  • Apr 30, 2010
As the title suggests I've been having some problems with my '95 lately. About every third start, it cranks and cranks but doesn't fire. Usually takes about 3 turns of the key before it kicks over, then usually stalls right after. After this it starts and idles. Under load, the engine cuts out almost like the fuel line is being pinched, most noticeable around 1500-2000rpm. Happens for a split second. It has been stalling at low rpm's, especially when left idling for a few moments. When it stalls, no sputtering, just dies as if I had turned off the ignition. This sounds like a sensor failing...any other ideas? Fuel pump/filter? Car has 174k miles. Thanks for any advice.
alleymad95GT
204
Okemos, Michigan
Apr 30, 2010
  • Apr 30, 2010
Assuming you have done all of the other routine things related to making the ignition work properly (plugs, wires, clean the MAF, etc), I think you just wrote a textbook entry that could be titled
"What you car will do when the PIP goes out."
Do you have any codes?
ProKiller
3,064
15
78
PA
Apr 30, 2010
  • Apr 30, 2010
BlackVert
5,589
9
98
Bethesda, MD
Apr 30, 2010
  • Apr 30, 2010
i'm not sure i agree 100% with the other 2 ... but it could be the pip ...
a more common symptom of a bad pip is the car suddenly dieing after being completely warmed up and running for a while, at which time it will refuse to start for 15-30 minutes.
breaking up while driving around at part throttle MAY be related to old oxygen sensors, but i'd try the other things first as new O2 sensors are not exactly cheap
is there any noticeable engine shaking?
in any case, i would start by replacing the distributor cap and spark plug wires, cleaning the MAf sensor, and installing a new fuel filter. i'd also put some fuel injector cleaner in the tank.
9
95five-oh
158
Mount Airy, MD
Apr 30, 2010
  • Apr 30, 2010
Plugs and wires are about 5k old, I ran a can of seafoam through the tank and brake booster about two weeks ago with no change in behavior. I'm gonna clean the MAF and TB tonight or tomorrow morning. I don't have access to a scanner but there's no check engine light showing. The car always cranks back up after a stall, its never taken more than a minute or so. The motor seems to shake when it cuts out at part throttle. PIP? What? Where? How much? Thanks again.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Apr 30, 2010
  • Apr 30, 2010
The PIP is also called the stator, it's inside the distributor under the cap. Put simply, it tells the computer when it's time to fire off each cylinder. If the PIP fails, it reports the wrong info to the computer which then can't keep the engine running. You can replace it yourself, but you have to take the bottom gear off of the distributor. That requires a press or careful use of a punch and a brass hammer. Here's a walkthrough on replacing the PIP:
How-To: Rebuild Your Distributor and Replace the Stator
9
95five-oh
158
Mount Airy, MD
Apr 30, 2010
  • Apr 30, 2010
Thanks for the info. Any idea on how expensive they are? I cleaned the MAF and air filter this evening thoroughly, and the problem remains.
alleymad95GT
204
Okemos, Michigan
Apr 30, 2010
  • Apr 30, 2010
$26.
AutoZone.com | | Pick-Up Coil | PICK-UP COIL
If you prefer Advance...
http://shop.advanceautoparts.com/we...-BWD_5240786-P_200_R|GRPTUNEAMS_848953205___#
Or NAPA...
http://www.napaonline.com/Search/Results.aspx?Ntt=stator&Ntk=Keyword&N=599001+101995+50026+2026026
Don't necessarily know if these are the best one or not, but...its a helluva lot cheaper than a Motorcraft one...
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
May 1, 2010
  • May 1, 2010
I thought ours was down by the air box?
Chythar
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
May 1, 2010
#10
  • May 1, 2010
  • #10
That's the TFI by the air box. Fox's had them attached to the distributor on the outside. The PIP has always been on the inside of the distributor.
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
May 1, 2010
#11
  • May 1, 2010
  • #11
Ahhh, gotcha.
9
95five-oh
158
Mount Airy, MD
May 1, 2010
#12
  • May 1, 2010
  • #12
Today i attempted to replace the sensor, but I didn't get very far. I was unable to get the distributor out...unscrewed the bolt and the hold-down, wiggled and pulled comprehensively...wouldn't budge and I didn't wanna break it. I'm very inexperienced with timing related issues. Any suggestions? Thanks
toyman
1,944
54
79
Vernon BC
May 2, 2010
#13
  • May 2, 2010
  • #13
Use a marker and draw a line on the distributor and engine. This will be your reference line when re-installing. Using a wrench try rotating the dizzy from below the housing. It will come free as there is nothing else holding it in place.
loopy
southcoast mass
May 2, 2010
#14
  • May 2, 2010
  • #14
I had the same problem in my 89, i didnt feel like tearing apart my distributor, so I bought a reman distributor from napa for $140 fixed the problem car running mint now.
P
pumperdriver
12
southern md
May 2, 2010
#15
  • May 2, 2010
  • #15
Just had issues with my PIP, car was shutting down while driving. I just replaced the whole distributor, a lot less time consuming considering you have to pull it out n e way. Why put back old parts? As mentioned in a post above..Dont forget to place a mark on your engine where your connector is on your dist and where your rotor is pointing. This will be a good reference when you re-install your dist. You will have to reset the timing afterwards. Good Luck.
Chythar
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
May 2, 2010
#16
  • May 2, 2010
  • #16
Remanufactured distributors do not always have a new PIP. The PIP will be tested to make sure it works, but their tests won't check for heat soak or other problems during operation. You can usually tell if the PIP has been replace by looking at the distributor gear. If there are two holes for a pin but only 1 pin, you likely have a new PIP. Most places that rebuild distributors won't bother trying to line up the pin holes in the distributor when reassembling; it's easier to make a new hole.
9
95five-oh
158
Mount Airy, MD
May 12, 2010
#17
  • May 12, 2010
  • #17
Replaced the Stator this morning and thoroughly cleaned/oiled the parts of the distributor. Result: Overall, car runs better, feels a little more crisp, but...the cutting out under load remains. At high RPMs its fine, only when accelerating at lower RPMs does this problem occur. Fuel issue? I've ran a can of seafoam through the gas tank, but no difference.
STM1965
185
Ontario
May 12, 2010
#18
  • May 12, 2010
  • #18
Seems this is more common then one thinks.....
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
C
1967 Mustang 5.0 swapped shuddering/sputtering issues
  • Cro67
  • Sep 24, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 25, 2025
General karthief
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
