  • 1994 - 1995 Specific Tech
harmoin balacer making noises? help?
  • Thread starter Thread starter sosstangs
  • Start date Start date Aug 19, 2005
sosstangs
  • Aug 19, 2005
Harmonic balacer making noises? help?
ok, i just finished installing my s/c on my 95 mustang gt. I am running 9 lbs of boost on stock internals. I cranked her up, and she started making some noise which sounded like it was knocking. But under further investigation, it looks like it is the harmonic balacer off the crank....It wobbles a little bit and Im wondering if maybe its the seal inside thats making it wobble a bit. How can I fix this problem? Do i need a new harmonic balancer? Or what does the balancer function as?
Any answers or advice would be greatly appreciated
Danny
tim95gt
44
Kernersville, NC
Aug 19, 2005
  • Aug 19, 2005
the balancer should not wobble so best bet would be to get a new one before it messes up the engine, it will only get worse
sosstangs
  • Aug 19, 2005
could it just be the seal inside the balancer?
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Aug 19, 2005
  • Aug 19, 2005
the balancer is not rebuildable. if it comes apart completely while you are driving, it can have a devastating impact on the motor. replace it now before it becomes a real problem. i would strongly recommend against replacing it with a stock one also. my recommendation from first hand experience is romac all the way. i just got my second romac off of ebay brand new for $100. (normally go for around $270-$350)
HISSIN50
34
129
Aug 19, 2005
  • Aug 19, 2005
The balancer quells torsional vibration. Follow above advice and replace ASAP if you think it is bad.
There is an inner ring which is bonded to an outer ring (which has your timing marks) and an elastomer joins the two. If the outer rings slips, torsional vibes will start to rip the motor apart.
Good luck.
ljinx23
163
Northeast Pennsylvania
Aug 19, 2005
  • Aug 19, 2005
I have one for sale on the classifieds if you are interested. Check it out under my SN.
sosstangs
  • Aug 19, 2005
thank for the info, i guess i'll be ordering it this weekend... i appreciate all the help and info.... What can cause this kind of thing to happen? PLease advise!
HISSIN50
34
129
Aug 19, 2005
  • Aug 19, 2005
They tend to wear out simply from revolutions-turned (once the elastomer loses its structural integrity, it fails soon thereafter). Ummm, what you just got done doing to the car can kill them off (9 PSI). LOL
Best thing to do IMHO is just get a quality unit - with the forced induction, I personally would get an SFI version, even if you dont track the car.
Good luck.
ljinx23
163
Aug 20, 2005
  • Aug 20, 2005
I second that one.
M
Mac-man
300
south texas
Aug 20, 2005
#10
  • Aug 20, 2005
  • #10
i third that comment..lol..if thats a word. honestly though get a new one. i tore up a lot of stuff in my old 93 gt when it decided to fly off, and ruin a few things. costed around 700 bucks to replace everything that got damaged, when it could have only costed 150 or so for a good replacement.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Aug 20, 2005
#11
  • Aug 20, 2005
  • #11
go down to my post for in in depth reason as to why you i suggest that you shouldnt go with a stock replacement. he he, just didnt feel like typing that novel all over again.
http://forums.stangnet.com/showthread.php?t=568533
Stripped Crank threads and cracked Crank Shaft Ring at end (what is it called?)
  • 69machmike
  • Nov 13, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 19, 2024
89ripper
Loose rockers. Silver oil.
  • SN95.ONASTY
  • May 15, 2022
3K
1994 - 1995 Specific Tech Jun 25, 2022
revhead347
M
  • mnky99
  • Sep 5, 2025
mnky99
M
J
  • JRC99
  • Apr 19, 2025
JRC99
J
G
Resolved URGENT HELP!!
  • Gilroy gonzales
  • Mar 26, 2023
  • SN95 4.6L Mustang Tech
3K
SN95 4.6L Mustang Tech Jun 1, 2023
Gilroy gonzales
G
