  • 1994 - 1995 Specific Tech
harmonic balancer install help!
  • Thread starter Thread starter grngt50
  • Start date Start date Mar 21, 2006
G
grngt50
250
Los Angeles
Mar 21, 2006
  • Mar 21, 2006
have a retarded question for ya'll....
How in the heck do you get the crank pulley bolts and balancer retainer nut off of the car? Everytime I try to loosen them the entire balancer wants to spin with the pulley and I'm not making any progress. And no I don't have air tools! Any help would be greatly appreciated!
-James
94GT Vert Aode
HGFireHazard
460
Michigan
Mar 21, 2006
  • Mar 21, 2006
What worked for me was having my friend hold a breaker bar with a 15/16" socket onto the alternator nut and that helped keep the belt from moving, thus allowing me to loosen to the bolts without everything spinning. If you already took your belt off, put it back on and give it a shot.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Mar 22, 2006
  • Mar 22, 2006
put the car in 5th gear
nm i see you have an AODE, crank shouldnt move when the car is in park
G
grngt50
250
Los Angeles
Mar 22, 2006
  • Mar 22, 2006
thanks, that makes sense. I'll give that a shot. I too thought that since it was an auto that the balancer/crank wouldn't spin while in park.
James
94 GT Vert Aode
Cobra intake, BBK 70mm t/b, 3/8 spacer, Granatelli MAF, K&N with silencer removed, BBK pulleys, MSD 6, MSD wires, BBK O/R H, 2 chamber flows, 4.10's, subframe connectors, 190 pump in tank, shift kit with rebuilt auto, weight reduction
HGFireHazard
460
Michigan
Mar 22, 2006
  • Mar 22, 2006
Sorry, didn't pay attention to that detail. Guess I was stuck in the 5 speed mode since that's what mine is.
N
Nagash01WS6
402
Deland, FL
Mar 22, 2006
  • Mar 22, 2006
You could just pop the flex plate cover off the trans, and but a breaker bar in the teeth of the flex plate and hold it still that way. Ive used a wrench before, worke great.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Mar 22, 2006
  • Mar 22, 2006
an aode car does not lock the converter when it is in park. the motor will turn freely. i think rob can answer this better. we changed the balancer on his car but i cant remember what we ended up doing to stop the motor from turning.
urban96
3,464
Syracuse, NY
Mar 22, 2006
  • Mar 22, 2006
i wonder if it would lock if you stuck the car in gear
you could stick some high strength rope down into one of the spark plug holes so that when the piston comes up it comes in contact with the rope and stops the engine from turning
MLC Stang
210
Atlanta, GA
Mar 22, 2006
  • Mar 22, 2006
Just did my balancer a few weeks ago, and I have an AOD-E.
This is what works every time for me:
I take a small length of 1/4 inch rope and loop it through one of the slots in the OD of the balancer pulley. Then I loop the other end of the rope around the smog pump and bracket and tie a knot! As you wrench the bolts, the rope tightens up and stops the assembly from turning. Works great!
One tip. That rope will really tighten up on you. To get it loose, just turn the crank the other way AFTER the bolt is tightened to put some slack in the rope.
N
Nagash01WS6
402
Deland, FL
Mar 22, 2006
#10
  • Mar 22, 2006
  • #10
No it wont lock when you put it in gear.
Automatic transmissions run on hydraulic principals. The only thing to stop the car from moving is a little nub on the inside of the transmission. The torque converter will let the motor turn over by hand as long as you want no matter what gear.
I would just lock the flex plate into place, they actually make a tool just for this, I found it when I was pulling the crank pulley on the LS1. A wrench worked great with someone holding it to keep the crank from spinning.
I cant say Id tie rope around the pulleys to keep it from moving, you could wind up breaking something else.
G
grngt50
250
Los Angeles
Mar 22, 2006
#11
  • Mar 22, 2006
  • #11
huh, that isn't a bad idea either....I'll give both suggested methods a try this Saturday and let you guys know the outcome. This sucks that for what seems to be such an easy swap for most is such a pain in the arse for me. Thanks for all the help
_james
HISSIN50
34
129
Mar 22, 2006
#12
  • Mar 22, 2006
  • #12
James, are you using impact tools? The shock loading of an air-impact-gun might break it loose for you.
G
grngt50
250
Los Angeles
Mar 23, 2006
#13
  • Mar 23, 2006
  • #13
unfortunately no, I don't have a compressor. But I am sure it would break loose the nuts and bolts in a heart beat. I guess I'll have to try the ghetto method with the ropes! Ha ha I'll let you guys know how it goes this Saturday.
-James
Zero Signal
2,633
Tucson, AZ
Mar 23, 2006
#14
  • Mar 23, 2006
  • #14
Just superglue the socket and 1/2" ratchet with a 3' bar welded to the handle to the crank bolt and start the car. Works every time.
MLC Stang
210
Atlanta, GA
Mar 23, 2006
#15
  • Mar 23, 2006
  • #15
OK... you really should have put somes smilies around this suggestion so some poor noob doesn't actually try this!
Yikes!!!
G
grngt50
250
Los Angeles
Mar 23, 2006
#16
  • Mar 23, 2006
  • #16
wow, I haven't had nearly enough to drink yet to even consider that one! Well, my dad is lending me his electric impact, so hopefully that will provide enough initial torque to pop those suckers off.
-James
94GT
HISSIN50
34
129
Mar 23, 2006
#17
  • Mar 23, 2006
  • #17
James, if not mentioned yet, make sure you REMOVE the washer under the bolt once you get the bolt out, or you can break a removal tool pushing against the washer.
John's method is a (tongue-in-cheek, I hope) variant of one that I have seen people use (using a breaker and bumping the starter). I dont post that kind of stuff even though it's done, since someone could find themselves on a Darwin-award list if it goes wrong.
G
grngt50
250
Los Angeles
Mar 24, 2006
#18
  • Mar 24, 2006
  • #18
good lookin out on the washer removal tip, I didn't even think about that.
-James
94GT
Wanting to replace my BOSS 351C Engine Harmonic Balancer - Questions about 'Balance?'
  • 69machmike
  • Oct 31, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 5, 2024
Realmongo
Stripped Crank threads and cracked Crank Shaft Ring at end (what is it called?)
  • 69machmike
  • Nov 13, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 19, 2024
89ripper
doing harmonic balancer for first time
  • mattys91gt
  • Apr 9, 2022
  • 3 4 5
8K
Fox 5.0 Mustang Tech Apr 11, 2022
General karthief
N
Engine 1994 Mustang GT AODE puzzling issues
  • noah5slow
  • Oct 22, 2022
2K
1994 - 1995 Specific Tech Oct 29, 2022
noah5slow
N
Autocrossing my 95 GT convertible
  • Bill95
  • Dec 6, 2021
5K
1994 - 1995 Specific Tech Dec 25, 2021
7991LXnSHO
