  • 1994 - 1995 Specific Tech
harmonic balancer install: is the specific tools a necessity?
  • Thread starter Thread starter fiveoho
  • Start date Start date Apr 2, 2007
fiveoho
1,958
TN
Apr 2, 2007
  • Apr 2, 2007
wondering how hard it is to replace the balancer and if you have to use the harmonic balancer puller and installer tools?
if its a have to, can those tools be borrowed from autozone i wonder with that lend-a-tool ( whatever its called )?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 2, 2007
  • Apr 2, 2007
This answer is one of those ... it depends upon ... kinda things
As for the removal
Almost a 100% sure fire thing you'll need a removal tool which can be
purchased or rented from a local auto parts store.
As for the install ... If ... and ONLY IF ... you can put the hb on the crank
snout and catch 3 to 5 rounds of threads with your fingers or VERY LIGHT
use of the ratchet and socket ... then I'd tell you to go on and pull it on
down with the ratchet.
I'd also tell you use some fine emery cloth on the crank snout and hb to
remove any burrs and also to use anti-seize to help things slide smoothly.
If you can't catch but one or two threads or the effort to tighten the bolt
becomes excessive quickly ... then stop and investigate things for why
such a great effort is needed.
You may feel more comfortable using an install tool
but
Just use common sense about not hosing up your crank snout threads
Now ... if you choose to go with a Romac ... Forget all that stuff
and
See what methods those folks went through with their install.
Grady
fiveoho
1,958
TN
Apr 2, 2007
  • Apr 2, 2007
thanks grady.
its just a FRPP oem replacement 50oz non sfi....the ugly black one.
not sure if i have the same one, but i have read several guys have to notch the waterpump
Red1990Lx
79
Ohio
Apr 2, 2007
  • Apr 2, 2007
I would definately rent or use the loaner tools to remove the balancer, it makes things ten times easier to remove. Also, this wont apply to your case, but if you were to reuse the HB; undue stress to the outside of the HB is a big no no !!! That undue stress damages the HB for obvious reasons... if that is your only ride, you may want to get the installer as well, they normally come in the same kit though...
gcomfx.com
3,690
Republic, MO
Apr 3, 2007
  • Apr 3, 2007
Just rent the kit. I couldn't find one to rent, the tool is less than $20 to buy. So I have my own. Ended up using it more times than I thought I would. Cheap stock replacement HB are the debil.
fiveoho
1,958
TN
Apr 3, 2007
  • Apr 3, 2007
rented the puller/installer at advance last night...holy crap. $98
course, i get all the back but jeez. we got the old one off and put the new on. but we did grind a bit on the bottom of the water pump. it was a VERY close fit, one credit card gap. now there is a easy 2 card gap between the two.
my old balancer didnt look terrible but the car is a little smooth with the new.
thanks guys!
parchisi
519
New Mexico
Apr 3, 2007
  • Apr 3, 2007
I had no problems just installing my HB the way Grady delineated, just be careful.
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
Questions Replacing Cam Synchronizer
  • Blackout67
  • Jul 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 23, 2025
01cstang
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
