  • 1994 - 1995 Specific Tech
harmonic balancer install tool
  • Thread starter Thread starter rockin_rick
  • Start date Start date Apr 25, 2004
R
rockin_rick
968
Apr 25, 2004
  • Apr 25, 2004
What does this tool look like and how does it operate? Is it just a stud with a washer and nut?
Would a stud and nut work OK? Then you would have all the threads engaged, and not risk stripping out threads if you only have a few engaged and try to 'pull' the balancer on with the bolt...
Rick
AznStanger3v
2,026
Northern VA
Apr 25, 2004
  • Apr 25, 2004
Rick
you are trying to put the balancer on??? you can use a rubber mallet and tap it on.
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Apr 25, 2004
  • Apr 25, 2004
Use the mallet and tap it on then just tighten down the nut and it will pull the balancer into place.
AznStanger3v
2,026
Northern VA
Apr 25, 2004
  • Apr 25, 2004
the only toll you really need is the pulley puller. i purchased mine from autozone today for $15.68. that includes tax.
R
rockin_rick
968
Apr 25, 2004
  • Apr 25, 2004
Actually, I'm building a new engine. I was just wondering how the install tool works, since some people have problems with theirs (unable to engage threads, too few threads, etc.). Anyone know how the tool works? I was thinking that if it is just a stud and nut, I could go to the hardware store and get a long bolt and nut, and use it as a stud. I'm assuming that a stud (in that size) is not available.
Rick
Black70Fastback
319
Dyer, IN
Apr 25, 2004
  • Apr 25, 2004
well i think that most people in here, including me, just used the balancers own mounting bolt to pull itself on.
if you cant get it on far enough to catch threads with that bolt, it may not be fitting right. but otherwise you probably can get a stud and a nut to do the job.
R
rockin_rick
968
Apr 25, 2004
  • Apr 25, 2004
Yeah, I'll give the bolt a try, just developing a backup plan.
Thanks,
Rick
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Apr 26, 2004
  • Apr 26, 2004
If you run into interference, just heat the balancer to 200°F in the oven and it will prob slip right on.
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
  • Locked
SOLD Maximum Motorsports MMTR-2 Bumpsteer Kit - 1979 - 1993 Mustang
  • AeroCoupe
  • Apr 18, 2025
Fox Body Mustangs For Sale (1979-93) Aug 5, 2026
AeroCoupe
