I have a '68 Mustang,but I changed the motor from a 289 to a '71 302 and changed the C4 to a T5. The engine developed a clack, clack noise and when I took it apart 3 pistons are scored, so I have to replace all the pistons as well as the cam. (one lobe wore). But my question is, when I removed the harmonic balancer it is a E4TE-A3A 4 bolt, which I think is a 50 oz. On a '71 302, should it not be a 28.2oz?
The flywheel is 157 tooth 28oz imbalance.
Also, when I checked the crank it had M1 on it, so I think it is a 289 crank. Engine also came with 351 windsor heads because of the high dome pistons that were installed. (.030 over)
Thanks
Thanks
