k so the vacuum part is normal
the 02's do affect the ltft (long term fuel trim) which overtime updates the fuel tables to adapt to your engine....but if you just changed the computers and assuming you disconnected your battery when you did that I don't think it would have enough time to affect the WOT tables that bad....
the part you're talking about with the fuel pressure is kinda sounding like a clogged fuel filter.....when you go WOT (big need for fuel) it bugs out but if you go slow and easy its ok......
yes, but I've changed the fuel filter twice already and it did not remedy it...
and I installed the new e-bay walbro 255 pump two years ago but the car has set for most of that time driven less than 50 miles.........
here's the maf test results:
#1 vpwr to ground 11.87
#2 maf sig to ground 100.2 kilo
maf sig to maf return 129.2 kilo
#3 maf sen voltage .920
before I drove it to get parts the
last koeo codes: 81,82,85
cm codes : 19 ,41, 91
koer: 41,91,33
cylinder balance test is 90-90-90
