Has anyone checked out AJE's new front end?
i just noticed today while flipping through the M&F magazine.. apparently Ron Morris has a coil over kit that can be used with the stock style arms. Might compliment that CPP front end nicely... or open tracker's stuf. i think it comes with the two coil overs and it replaces the spring perch.
http://www.ronmorrisperformance.com...mp&Product_Code=5160&Category_Code=Susp_Parts
would you need to change or modify anything to install these bad boys on a '65 or do they just bolt right up?
just click the links and do some research. alright, i'll do it for you.
CPA kit:
"EXCLUSIVE
CPA new exclusive Front coil over front suspension available in several kit forms starting at $799.00 aluminum 12 way adjustable coil over shock,1/2 inch piston shaft, custom constant rate springs for your application, custom upper and lower mounts and spring pads.
ROLLER BEARING CONTROL ARMS,
ROLLER BEARING IDLER ARM, HEAVY SWAY BAR,
LARGE BEARING SPINDLES,
THE SKY'S THE LIMIT. "
Ron Morris kit:
1965-70 Mustangs
Will work with Stock or Aftermarket Control Arms
Replaces Stock Coil Spring & Shock
Adjustable Ride Height
Adjustable Shock Dampening
Street or Street/Track Springs
Double Adjustable Shocks Available
Matching Rear Shocks Available
Pardon me for interrupting, but if the RM and CPA 'coilovers' (shock kits) listed here bolt up to the stock locations... there is no geometry or motion ratio gain, right? So the only gain by these systems is the adjustable shocks and ride height? Oh, and the benefits of roller...
Is it me or does >=$800 sound a bit steep for these abilities?
RM sells their full on coilover for $2250...with geometry,motion ratio, roller, and non binding strut rod benefits included. It might be only my opinion, but it seems that the $800 would be better spent towards more beneficial products (AJE or otherwise).
Ed Cole was the chief design engineer on the 265 SBC. He worked for Chevrolet. Not some independant firm. He later became president of GM He died in a plane crash in May, 1977.
In 1952 his engineering team was given the task of building a v-8 engine for Chevy. The rest is history. That you apparently don't know much about.
Too much Wikipedia....
I read it somewhere, it has to be true......
$2250-800 = $1450 left to improve your front end.
$1450 > $800 (CPP extreme kit) = $650 savings.
The RM and CPA kits aren't complete packages on their own, but allow you to add the benefits of a coil over shock to a setup which would otherwise be using stock style springs.
exactly. the big benefit of the TCP, RM, and GW, full coilover kits is that they move the spring/shock combo to the lower control arm thereby reducing wheel rate, the CPA and RM coilover kits for the stock arms will get no reduction in wheel rate but it does free up the some of the binding in the front end and allows you to adjust ride height, and probably corner weight as well, using a stock style suspension. combine these with the CPP mini subframe kit, the regular GW Negative Wedge upper control arms, and of Opentrackers roller arms, etc. etc. and you get a better stock style system i'd imagine since the CPA and RM coilover kits are so similar (fundamentally) to the stock setup that they'd probably be legal in a bunch of different racing classes as well, that's just a guess though.
No, just growing-up in the 50's and 60's as a car nut. Something you young boys can only read about in history books I read about as it happened. So it's a part of my life where as it's NOT a part of yours.
what freaking difference does it make when you read it? i've been reading hot rod, car craft and PHR since i was like 5 or 6 years old, i got my first Hot Rod susbscription when i was like 7 and it was addressed to me. so what?
But that's what I'm saying... the benefits of a full coil over setup are mostly dropped here. This is just a nice and pretty package of a new set of springs and shocks (or slightly more) for $800 that could, in itself, be used to provide much more beneficial gains... upper arm relocation, Opentracker's perches or whatever. That $1450 left to improve your front end could be $800 more with better realized gains. "Savings" on a product that doesn't provide value is no savings at all. Not that I don't see benefit here... I just see far below $800 worth.
Freeing up some of the binding in this suspension is definitely a worthwhile goal... but $800 for something you just said is so similar (fundamentally) to the stock setup that they'd probably be legal in a wide range of racing classes doesn't scream to me to be the holy grail of compromises.
Just my opinion though...
This thread to me is extremely disappointing. I came back from a break and saw there was a few new pages to this thread, of course, the majority of it was a useless debate and none of which related to AJE. Sigh.. :nonono:
Well..let me see...someone said the SBC was offered to Ford 1st when it was a totally in house project and they then attributed that information to a Mr. Smokey Yunick. Now I don't believe Smokey ever said that unless he was testing some reporter to see if the guy knew anything. Which he would do from time to time. And if the person who posted that on this forum knew anything at all about the SBC he would have know that Ed Cole was THE man on the project and was never employed as an engineer anywhere but GM. Around 45 years worth.
So it does matter WHERE you read it. It also matters that what is going on during your sife in a given subject is probably more interesting to you than what happened before your time. Kind of like Auburn Speedsters....before my time...cool cars...but I don't care much about the details of who enginneered and built them. Whereas I grew-up in the 50's/60's and THE performance car on the street during that time was the SBC. That is a fact you cannot deny. You can ignore it, but it is still THE street performance king since its introduction in 1955 until the last year of production in 1997.
Facts are facts...nothing could beat the 426 HEMI at 10 lbs per cube so NHRA gave everyone else a weight break and then piled on another 100 lbs every time a Hemi won an event until it could no longer keep-up. And the 302 Z/28 engine was the best small block carburated engine of the 1960's.
Did Ford build good engines? Sure, but you couldn't get parts for them unless you were on the factory good-ole-boy list. So what good were they? They were good for those of us who had Chevy's to take their money on Saturday night. I only know of one person (BIll Newton in Charleston, SC) who ever consistently won on the street with a Ford.
That's just the facts of street racing back then. You may not want to believe it. Doesn't change it.
That was an unfortunate post; there was no "small block" formula that anyone owned and that he could shop it around from one manufacturer to another.
Anyway, as far as the primacy of the SBC, my understanding of the hot rod family tree is to begin with the '32 Ford V8 flattie. For nearly 20 years there was no other hot rod engine -- unless it was a Ford Model A four.
Next in the timeline I would put the Ardun heads for the flattie. Zora Arkus-Duntov did not invent overhead valves or hemi heads, but this product made them available (more or less) to the masses.
Next is the '49 ohv Cadillac and Oldsmobile (aka Rocket 88) ohv V8's. These were the first regular production ohv V8's. They provided the template for all the pushrod ohv V8's which followed.
Next is the '51 Chrysler hemi, which became the first mass-produced hi-po V8.
Next is the '55 small block Chevy, the first thin wall V8.
There should be another landmark for the big block V8. I would count the 1958 intro of the Ford FE as the first, although the big cube concept did not really kick in until the subsequent release of the 390's, 406's and 427's. There was also the Chrysler wedge-head "B" engine family, which replaced the hemi in '59, and which remained in production more than 20 years.
It took Chevy until '65 to catch up, with the 396 (although I believe there was also a very tiny run of '64 396 ci Malibus.) (I am counting only landmarks, and the Chevy 348/409 did not have the staying power to qualify as a landmark.)
And then there is the '65-'71 426 street hemi.
In other words, in the grand scheme of things the SBC is a landmark, but it is a crowded field. (I have left out many others.)
If the 302 was good, why wasn't the 365 hp 327 SBC better? It's the exact same recipe with 25 more cubes. And I don't believe anyone could argue the splayed valve heads on the Boss 302 didn't have more potential than the SBC's wedge head. In the '69 Trans Am the Boss 302 consistently enjoyed a 25-50 hp advantage over the SBC. In what sense was the Z/28 302 "better" than the 327/365 SBC or the Boss 302?
blah,blah, blah, blah, blah. i'd take a 365hp/327 over a 302 Z motor anyday, the ONLY reason chevy even built the 302 was to go trans am racing and be under the 5.0 limit. Ford made lot's of parts or have you never heard of the Ford Power Parts program from back then? i'm don'e with you, you're so full of yourself i can smell from you Texas
The 302 had a 1.9-1 rod length-to-stroke ratio, which according to some engine builders I know is the optimum ratio. And if you check the hard-core *** sport bikes the lowest ratio is 1.86-1 with some past 2-1. The 1967 ENGINE OPTION Z/28 was a fuelie block-heads-cam (the famous '30-30' cam..called that due to the .030 valve lash on both intake and exhaust) with a 283 3" crank, Then in 1968 they used a 4-bolt main block...ant THAT made the 302 a better engine than the 327-365.
The heads on the BOSS-302??? TOO DAMN BIG...period..you had to rev them past 8000 to make real power and you could not do that with a stock 5.15 rod in a street motor like you could in a 302 Chevy. BTDT..broke 7 piston at one time. I firmly believe that had Mark Donahue and Roger Penske raced the Z/28 in 1970 instead of the AMC that THEY would have won the T-A title.
Most builders I knew back when Cleveland motors were in production said you needed 50 cid per cylinder to make that head work properly...and I believe them.
Look, the Ford LeMans 427 was a great engine, better than the same year 427 Chevy mostly due tothe 7/16" rod bolts and good rockers vs. the 3/8" bolts and crap rockers of the Chavy. But tell me why Shelby put mostly 428 P.I.motor in his BB Cobras?......Ford didn't have enough 427's to go around. What is a better engine...a ferrarri 12 cylinder or a push-rod anything built in the USA? Well, the Ferrarri, of course....until you start to need parts. THEN a big inch USA motor with good parts availability and price starts to look pretty darn good. I had the premier sport bike of the early 70's in a Norton Cammando...a much better ride than my old XLCH Sporty, trouble was the Norton sat waiting on parts under warrenty for 8 of the 15 months I owned it.
One other thing..you could buy a 396/375 option in a Chevy for less money than a 289/271 option in a Mustang. How would YOU have spent YOUR money?
