have you seen this?
Yep seen it before..Was "alot" of threads on here along time ago about it..Can get the stuff from radio shack .Actually can get a adj one to where you can adj the ohm's..think its called a Potentiometer..It just fools the ECU and makes it run richer..
like i said,it fools the ecu..instals in the IAT wires,makes the ecm think its getting a cooler air temp and couses the ecu to richin the motor..it works as to richin it up,but not so sure its a good idea,might do more harm than good,esp for MPG..maybe some of the other older members on here can tell you more or do a search on it and might be able to find some of those old threads
Yeah, we've had this before. Like blueoval said, all it does is pump in more gas and make it run richer. So, basically, you would have basically no gains, your mileage would tank it bad, and you could wind up pumping in more fuel than can be combusted, and so, lead to alot of waste and actually hurt performance... not even worth $8 I'd say...
