  • 2005 - 2009 Specific Tech
having a flash tuning problem. Help??
  • Thread starter Thread starter CanonGotaRoush
  • Start date Start date Mar 6, 2008
C
CanonGotaRoush
florida
Mar 6, 2008
  • Mar 6, 2008
I joined to try and resolve this issue... I bought a 2005 Roush Sport a few months ago and couldn't wait to start bolting on some upgrades. That said I ordered "the e kit" from rpm outlet because I figured i'd be getting the most bang for my buck. Anyways it came with c&l racer intake and a 95mm MAF, gt500 throttle body, i bought a spacer along with it, a set of underdrive pulleys also. It came with an sct sf3 tuner, which i knew i would need to make this system function properly. I got the intake and MAF, and the underdrive pulleys and C.O.P.s so far and wanted to go ahead and try to use the tuner and see what results i had. I'll go ahead and be honest and admit to knowing absolutely NOTHING about tuning a car, but i figured if i played with it long enough i could get it running right.
Here is what happened despite what i tried to do with the tuner: The engine seemed to be running fine at start up. I noticed the strong smell of gasoline and also a lot of extra smoke coming out of the exhaust as if it were running rich. As far as driving the car, it seemed to be running ok but i slowly accelerated because i didn't know hwo the engine was going to react to the bolt ons, at 3500 rpm the engine completely bogs down in every gear. I tried nearly everything i could think of with the tuner and it just kept bogging down at 3500 rpm everytime. I got frustrated after about an hour of fiddling with the tuner and not getting any change in results........ can ANYONE help me?!!!
Redfire 05
236
Lubbock, TX
Mar 6, 2008
  • Mar 6, 2008
You listed a bunch of parts there. You say you got some, but did you install anything except the tune? If not that might be your problem. The tune should be set up to work with the other parts, and it probably won't work right without them. Try reinstalling the stock tune to see if that resolves the issue.
If you put the throttle body on it could be causing the problem. I had a similar problem when I installed a BBK throttle body. My car would idle at a high rpm, smell like gas and smoke. I'll attach a link to an article below that you should read through. It shows how to adjust the TPS readings in case they are not reading correctly with the new throttle body. I'm not sure if it applies to the cobra throttle body, but you can check and see.
http://www.americanmuscle.com/bbk-trouble-shoot.html
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Mar 6, 2008
  • Mar 6, 2008
I don't know who does the tunes for RPM Outlet, but for future reference, steer far clear of them. MANY MANY MANY people have had troubles with their customer service. Just do a quick search an you'll see.
As far as what you're experiencing, I would get a real tune from Doug at bamachips.com or Brent at brenspeed.com
Either of those tuners are going to give you a lot more performance than the tune you currently have, and it'll run correctly.
C
CanonGotaRoush
florida
Mar 6, 2008
  • Mar 6, 2008
Thanks for all the advice guys, i just sent an email to Bamachips to see if he can hook me up with a tune. I just hope his tunes will work with the sf3, from what i gather the sf3 has preceded the xcalibrator3.
About the Throttle Body. I haven't installed it yet it wasn't shipped on time with the rest of my parts.... imagine that... i won't be buying anything else from rpmoutlet.....
D
dumps
15
  • Mar 6, 2008
doug from bamachips is great for helping with problems, he gave me lots of help and spent lots of time e mailing back and fourth with me to fix a problem i had. in the same breath i have had very good experiences with brenspeed too, both have excellent customer service and tunes.
05xgt
78
spring tx
Mar 10, 2008
  • Mar 10, 2008
I dunno, think the're all about the same. I had a tune go bad in my 05 bout a week and a half ago and am still waitin to hear back from Doug. Heard from him once and that was it. Think it's time to get it on a dyno and be done with all the BS.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
2005 - 2009 Specific Tech Sep 6, 2025
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
