Having trouble finding injector caps... ahhhhhhhhh
Pintle caps. B-W makes a kit which should have o-rings and pintle caps.
Get extra pintle caps if you can cuz they like to break. A member on here posted a tip about heating the caps in hot water before installing them to help them snap into place easier.
Good luck.
the pintle caps im talking about...
hey hissin do you have a link or know where i can go to buy them.. i think it was RIO that said he got his at napa but they looked at me crosseyed when i asked for em and only had o-rings listed :(
attachment.php
Try HERE, HERE, or HERE.
yellow1995Cobra said:
Nope, same thing.
What he said... :D Look familier Jesse?? The number wont jive if you tell em 95...These are generic to Ford and cover alot of years..As mentioned get a few extra kits...The mothers get almost all the way down then "snap"...I think I found a socket they fit in and used that to help out...
actually, the ones for the 19lb injectors are different from the 24lb injectors. they will not fit. the napa near me can only get the correct ones for the stock 19lb units. i went through this when i accidentally dropped an injector during a lower manifold swap.
