just recently i had a procharger installed on my 97 mustang gt. i allready replaced the engine with an 03 gt. my problem started when i was traveling down the road in third on a pull up to 5000 rpms. i had noticed that my car started spark knocking like crazy. almost immedately after i noticed the spark knock something let go in the engine. it started to knock and skip like crazy. so i shut the motor down. when i started the car back the knock stayed around for like 3 seconds and then went away leaving just the skip. i carried the car back to the house and started pulling plugs. i noticed that one of the plugs had the gap closed on it and the stone insulator broken off,"a very small piece". so i replaced the plug and started the car back up. the car run like a champ when i started it and left it at idle for about thirty minutes. no knocks no smoke, nothing!! i then took it down the road and on a slight pull at 3200 rpms it done it again with the knocking. a second or two later it's gone. i go back to the garage and pull the same plug and nothing happened to it. i pulled the valve cover to see if i could see a broken valve spring or any scaring on the cam and there is none. it's gotten me stumped. i've been told that it may be some pre detonation from some crappy gas. is there anything else that i may be overlooking???? PLEASE HELP!!!
