i just purchased an adjustable hayden fan relay from cut rate today. my mark 8 fan is currently wired so its always running. im doing some research on this controller, and im seeing an issue.
i stumbled upon someone saying the mark 8 fan, draws 90 amps at initial start up. this thing has an inline 25 amp fuse. is anyone running this combo? so do i just need to buy and splice in a larger inline fuse?
it is doing fine now on my 30 amp hvac control fuse now.
actually, is there a better suited controller i can get at cut rate? p/n on the controller is 4003647-01. it uses a probe into the radiator fins, i have transmission cooler provisions on my radiator, i was hoping to use one of them if it helps accuracy.
it is doing fine now on my 30 amp hvac control fuse now.actually, is there a better suited controller i can get at cut rate? p/n on the controller is 4003647-01. it uses a probe into the radiator fins, i have transmission cooler provisions on my radiator, i was hoping to use one of them if it helps accuracy.
