Head Boost ??
  • Thread starter Thread starter vpap1
  • Start date Start date Jul 2, 2011
V
vpap1
109
  • Jul 2, 2011
Have a 10:1 NA 347 with track heat top end kit
with a tfs stage 2 cam, and all supporting mods and then some
Thinking of adding a twin turbo set up to make 650hp at flywheel
Will 10-15 pounds do it?
can i use the 170cc tack heat heads or is it way too much of a bottle neck?
V
Rick 91GT
Mustang Master
95
99
PA
Jul 3, 2011
  • Jul 3, 2011
With 10:1 comp you'll most likely need more octane then 93.
If your making 450flywheel, 10lbs should get you there. The TFS 2 is not the best turbo cam, if you go custom you can bleed some of the cyl pressure off to help with the 10:1 comp. Is this all on a stock block? If so your on borrowed time.
Rick
Owner/Operator RNH Performance
2000xp8
SN Certified Technician
Aug 8, 2003
8,071
1,655
194
NJ
Jul 3, 2011
  • Jul 3, 2011
If you are talking a stock block, forget the boost.
Save yourself a ton of money and just have your heads cnc ported by TEA, go custom cam, and sell off your intake for a edelbrock vic jr, get a 75mm TB, 30lb injectors and you should be in the mid low 400's, for a tenth of the price the turbo is going to cost you.
V
vpap1
109
  • Jul 3, 2011
No, not on a stock block. Its aftermarket with a main girddle. Tech says good for 650 fly hp. Main goal is to hit mid to high tens with as much of the parts I have already. And I want the power all the time. I do have a nitrous kit (125hp shot) that is going to push me to mid 11's. I should have around 380 ish to the fly as it stands and 125 shot should get me 11's easy with 3.73's. But having the power all the time just sounds much better.
PS I have a 80 mm maf, a 75 mm tb and 30# injectors already
V
2000xp8
Aug 8, 2003
8,071
1,655
194
NJ
Jul 3, 2011
  • Jul 3, 2011
V
"not a stock block" is a little vague for an answer.
Since you suggest it has a girdle, it probably is a stock block nobody puts a girdle on an aftermarket block.
What's the block brand and model? Not to be confused with the company who put it together, or the engine internals.
And for the record, nobody talks flywheel hp, it's all rearwheel, because once an engine is installed the only method of measurement is to the wheels.
lancec2c30
570
Washington
Jul 3, 2011
  • Jul 3, 2011
Is this a dss shortblock or something? The main girdle won't do much but increase the chances of saving an expensive rotating assembly when the block let's loose.
With the 10:1 I would just run a bigger wet shot on a intake spacer kit or something.
V
vpap1
109
  • Jul 4, 2011
Its a 302R block. i use flywheel hp to describe the hp capabilities of the short block. Despite if the bock can take the hp it, back to the question.
Would 10-15 pounds of boost make the hp goal? And would the heads prevent me from getting there?
And I enjoy the nitrous but not when I can't use it on the street, hence wanting turbo for power all the time.
So any input?
Rick 91GT
Mustang Master
95
99
PA
Jul 4, 2011
  • Jul 4, 2011
WhileI would prefer to see a larger head I believe you can get to your goal with 10-15lbs of boost.
TEA does a good job with the TFS
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
C
Fuel pressure help
  • clayton seiders
  • Aug 31, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 1, 2024
clayton seiders
C
Top End Kit or Supercharger?
  • 93gtmustang
  • Feb 24, 2024
  • 2 3
7K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 2, 2024
Bullitt347
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
