Head Change on 5.0
spider21
I have done a Head change on a mustang and cannot screw in bolts to the new heads to mount the alternator the holes are bigger than the original heads please advise ...
Thanks
You need to buy thermactor plugs and screw them into the head.
http://store.summitracing.com/defau...rchinresults=false&N=115&target=egnsearch.asp
Check the back side of the heads. If I remember right, putting the heads on the wrong side (L vs R) will place the accessory mounting holes in the back of the motor. That the only dif between right and left.
Good luck
spider21 said:
what do the thermactor passages do
They connect to the exhaust EGR system for emissions. On the back side of stock heads the passages are left open and hook up to a crossover tube that hook up to an air valve that are part of the emissions system.
Put some rtv silicone on the threads when you install them. My AFR's could have been used on either side (left or right) because they had the same "holes". You will need them either to block the smog passages or bolt up your alternator and install the powersteering stud.
ok will do and I did not flip them around they have the same holes on both sides of the head... The reason why I asked about the rear is that when I ran my old heads they were not plugged either. Does Exhaust come out of those ports ?
