head flow vs intake
jghood13
160
NY
1. I wana follow rio95's route with the gt40p's and the street heat intake but what would I need to do too the heads to have them flow as well as the intake.
2.when the heads out flow the intake does it help performance with out porting the intake.
3.my goal is 12.xx just want to do that n/a.
I have never seen or heard of a set of P heads that went to 260 CFM. You'd spend much more than what the heads are worth if it were possible to get them there (probably in the $2000+ range, if possible).
Heads that outflow the intake will only go so far without porting the intake. Not that you want a "bottleneck," but, if anything were to bottleneck the airflow, you would want it to be your cylinder head. You will never realize full potential if your manifold cannot keep up.
Joe
i just want to spend as little as possible to get the results from the car that I need for 12.xx and keep the car a DD.
Could I do this with the e7's or would I save money going with P's
